Missing or stutter in engine
Old Aug 1, 2016 | 11:04 AM
junker98's Avatar
junker98
4th Gear
Default Missing or stutter in engine
2015 coupe LT1
When at speed of 35 to 45 I feel a stutter in the engine. At low speeds it is very pronounced. At speed of 60 to 70 it turns into a rhythmic vibration you can feel at a regular interval a few seconds apart. No fault codes show but running a OBD the number one oxygen sensor is all over the place while the number two is fairly stable.
If anyone else has an OBD I would like to know if that is normal.
It was back to the dealer but he they said this is normal. It wasn't normal for the first 4000 miles. Tailpipes also carbon up badly.
Any help would be appreciated.
Old Aug 1, 2016 | 11:13 AM
Stinger15's Avatar
Stinger15
Originally Posted by junker98
2015 coupe LT1
automatic?? If so bad transmission.
Old Aug 1, 2016 | 11:32 AM
HoustonMidtown's Avatar
HoustonMidtown
2015 coupe LT1
See if you have the symptoms in this thread: https://www.corvetteforum.com/forums...here-i-go.html
Old Aug 1, 2016 | 01:19 PM
Ernest_T's Avatar
Ernest_T
Sounds like you have a transmission issue.
To Missing or stutter in engine
