My 2016 Z51 A8 slips a little going into fifth gear in a mild to moderate acceleration . The car has 2600 miles on it and has done this since new. Anyone have an idea what it takes to fix this ?
Wow, I have not experienced that with my 2016 Z51, A8. 1890 miles.
In mild to moderate acceleration torque converter lockup occurs shortly after this shift so are you sure what you see as slippage isn't the shift followed shortly by the torque converter mechanical clutch locking?
If there is actual slippage in the clutch packs the transmission will first try to adapt by increasing clutch pack apply pressure which will be remembered for future events and if that doesn't prevent slippage a DTC will be set illuminating the CEL. The 8L90, like other modern GM automatics, monitors rotational speed at multiple points in the transmission and if the shaft speeds aren't as they should be it will enter a protective limp mode and the CEL will be illuminated.
Try taking your car out for a "spirited" drive in M mode using the paddles to up and down shift at moderate RPMs. This seems to have greatly helped my tranny shift firmer and quicker. You can also get a copy of the drive "learning" procedure and perform it as well. I did this as well. It takes about 45-60 minutes of driving on back roads with little traffic as it does involve quite a bit of speeding up and slowing down.
My car has done this since new. NO other problems with the trans. I wonder if my driving habits have not caused this. When I leave my subdivision, I always seem to get to the 4 to 5 shift just as I reach the speed limit and therefore relax the throttle input just as it shifts (it also goes into V4 mode at the same time) so, am thinking that my trans has learned to sliiiide into 5th. Is this possible?
Just turned 14K miles on my 2015 Z51 A8. I'm fortunate, I guess. No issues with the tranny. Hope your question is resolved easily by some spirited driving in M mode....
The converter will be unlocked at lower speed in higher gears and at low throttle it will feel like its slipping. If there was a problem, since there is an input speed sensor and output speed sensor, if a clutch pack was slipping you would certainly see a check engine light. If the trans clutches were slipping that bad they wouldnt last long. But the PWM controlled torque converter clutch is meant to slip at certain rpm/throttle levels.
It's the 3c clutch disengagement. It happens in the 2-3 shift and the 4-5 shift because both of those shifts start with a 3c clutch disengagement.
It's called a soft shift. The time between the disengagement and the engagement in the next gear is a little longer resulting in a slight rise in RPM during shifts. Feels like a small surge when it engages the next gear.
Under a little harder acceleration it shifts faster and this does not occur. IME it usually happens around 2200-2400 RPM. Most noticeable with "around town driving".
It is considered normal. In a lower powered vehicle you wouldn't feel the surge and would just be a soft shift. AFAIK it is not converter related.
Thats what I thought too but I have noticed the slipping and when logging the converter went to full lock. I never really looked into it that much to be honest, since at higher throttle it doesnt happen. I notice mostly on the 1-2 shift under light throttle and higher rpm than 2500, almost feels like an extra shift. Thats what I was looking at mostly logging.
I have felt the medium throttle 4-5 slip and it can drag on pretty long, hard to believe they would purposely slip the clutches that long but anything is possible I guess. Anything over 1/2 throttle and higher RPM there is no slip felt so I was never that concerned about. It has acted the same way since day 1.
Volfan, I took mine out for a run yesterday. If I'm on the same page as you, that will be the torque converter locking up in fifth gear. Mine did the same thing you described. I only felt it at slower acceleration, and lower rpm levels. Mostly in town driving. I think you're OK my friend.
On my way to taking it to the dealer yesterday I noticed this while only in sport mode. I also tried it in manual and felt nothing ,but in the 55 mile trip I hardly had a chance to get on it for the traffic. We'll see what the pros say I hope it's my imagination ! Thanks for all the responses !!!
