Help
Old Sep 8, 2016 | 11:50 AM
AirStingray's Avatar
AirStingray
Default Help
So I'm driving on my daily commute on the interstate and everything is fine.. Next thing I know my RPM goes all the way up to redline on its own and then whenever I press on the gas nothing... When I put it in reverse.. Nothing. No movement at all. The car restarts just fine, no check engine, no nothing but it won't go!!! There's some fluid leaking from the rear but that's about it. What could this be?!
Old Sep 8, 2016 | 12:12 PM
123sugey's Avatar
123sugey
Dig
Trans or rear broke
Woodson's Avatar
Woodson
Old Sep 8, 2016 | 12:15 PM
cheapthrills's Avatar
cheapthrills
Auto or manual? but yeah tranny or rear went out.
Old Sep 8, 2016 | 03:10 PM
Never Settle's Avatar
Never Settle
St. Jude Donor '16
aw man, that hurts to see.. keep us in the loop what happened. good luck.
Old Sep 8, 2016 | 03:50 PM
kenownr's Avatar
kenownr
Jeeeeeezzzzzzzzzzzzzzz sorry to see that -- I agree with above tranny/rear-end took a dump. I hope Chevy road service warranty stepped up with some help. As someday above said -- keep us in the loop
Old Sep 8, 2016 | 04:01 PM
AirStingray
Auto tranny. It was a red fluid leaking if that helps.
Old Sep 9, 2016 | 07:37 AM
Kraz8s's Avatar
Kraz8s
Yeah.... that's trans fluid. Hope you can get this sorted out!
Old Sep 9, 2016 | 07:56 AM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
Thank goodness you have a GM drivetrain warranty. Have it towed to a reputable dealer. One that has knowledgeable Corvette service technicians.
Good luck and keep us informed.
Old Sep 9, 2016 | 08:32 AM
WelderGuy's Avatar
WelderGuy
Probably just a flexible line from the transmission to the radiator broke. They should not even have to drop the transmission to fix it.
Old Sep 9, 2016 | 10:42 AM
AirStingray
You are absolutely right. The line going into the radiator broke loose and all the fluid spilled right out. Hopefully that caused no damage to anything but we shall see.
To Help
