Motion Sensor Question
Old Sep 9, 2016 | 04:19 PM
dinows33's Avatar
dinows33
Default Motion Sensor Question
There is a button next to my trunk button that displays "motion sensor' I have gone through my manual 3 times and cant find it. could someone direct me to something that tells me what this does. Thanks much
Old Sep 9, 2016 | 04:25 PM
kenownr's Avatar
kenownr
I haven't found it in the book but it's my understanding that as you exit the car if you push the sensor button it turns off the "Interior Motion Sensor Alarm" for that cycle until the car is restarted. Then the default is:
"Interior Motion Sensor Alarm" active again when you leave the car the next time.
Old Sep 9, 2016 | 04:27 PM
kenownr's Avatar
kenownr
Sorry it actually turns off ALL the motion sensors on the car until the next start
Old Sep 9, 2016 | 04:28 PM
frsr06's Avatar
frsr06
What year - if a 2016 see page 6, 7 and 39 in the owners manual. Item 25 as explained on page 7.
Old Sep 9, 2016 | 04:30 PM
Silver Stingray's Avatar
Silver Stingray
Yep it disables the interior motion sensor. I have to hit that button when my dog is with me and I run into a convenience store. The first several times I did that without hitting the button she set my alarm off.
Old Sep 9, 2016 | 04:55 PM
dinows33's Avatar
dinows33
It is a 20 15
Old Sep 9, 2016 | 07:03 PM
BEZ06's Avatar
BEZ06
It is a 20 15
For the 2015 check page 2-18 Keys, Doors, and Windows:
Intrusion and Inclination
Sensors Disable Switch
It is recommended that the intrusion
and inclination sensors be
deactivated if pets are left in the
vehicle or the vehicle is being
transported.
With the vehicle turned off, press ^
to the right of the hatch/trunk
release button. The indicator light
will come on momentarily, indicating
that these sensors have been
disabled for the next alarm system
arming cycle.
It is hard to find when they don't call it the "Motion Sensor" like everybody else calls it!!
I turn mine off when I'm trailering the car to track events so it doesn't start honking for the whole trip.
I left my wife in the car once when I went had to go into a gas station because the pump wouldn't take my credit card swipe. When I came out the car was honking. My wife thought it was some other car!
Old Sep 9, 2016 | 07:59 PM
Quick99's Avatar
Quick99
Originally Posted by kenownr
i haven't found it in the book but it's my understanding that as you exit the car if you push the sensor button it turns off the "interior motion sensor alarm" for that cycle until the car is restarted. Then the default is:
"interior motion sensor alarm" active again when you leave the car the next time.
yep, this is the real deal, push the button and the alarm system is shut off, default position is on... Often use this when i leave the window open or the wife sitting in the car after i shut it off........
Old Sep 10, 2016 | 10:49 AM
Acrr46's Avatar
Acrr46
Was at a car show that was very dry and dusty day, and had the windows almost all the way up and the car locked. Left the car to walk around when someone threw a show flyer in my car. It set off the motion detector.
Frank
Old Sep 10, 2016 | 11:05 AM
Mike Mercury's Avatar
Mike Mercury
couple things on my 2015 coupe:
I hear a confirmation "beep" if I push that disable button.
Also, with the targa top off, the alarm seems to be disabled automatically.
Old Sep 10, 2016 | 11:16 AM
defaria's Avatar
defaria
transported.
arming cycle.
You need to get your wife's hearing checked!
Old Sep 10, 2016 | 11:18 AM
Maxpowers's Avatar
Maxpowers
I learned to use this feature in quick order.
First time getting gas. Wife is in the car. I go to pay and the alarm goes off. I don't notice for 10 seconds or so.
She wasn't happy about that.
Old Sep 10, 2016 | 11:21 AM
defaria's Avatar
defaria
Yes there's a thread here about that. On the driver's side on the top of the windshield where the top sinks into it there's a small hole with a little switch that if not depressed (top in on) disables the motion sensor. At first I, like many others, thought it dumb to disable the motion sensor with the top off. I mean would you really want it then? But as you can see the slightest thing like a leaf falling into your car will set the sucker off so it's probably better that it's disabled. But be armed with the knowledge that if your top is off so is the motion sensor.
Old Sep 16, 2016 | 07:20 PM
farne230's Avatar
farne230
yep got the same problem. Mine goes off when parked outside and the temp rises to 90 deg. Thunder and a yard blower can also set it off. Never had this problem with earlier model. Mine is 2016.
Old Sep 16, 2016 | 07:33 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Disguised ............
It is actually the disguised ejection seat button for the passenger seat .......
Old Sep 16, 2016 | 08:22 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Side note, it is deactivated if you have the top off, put a marret in the driver's side front roof pin hole if you want to keep it active. Why GM made it like this I have no idea, makes ZERO sense.
Old Sep 16, 2016 | 11:52 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
^^^ Wonder how many have never heard of William P. Marr, the inventor of the wire nut.
Old Sep 17, 2016 | 12:02 AM
owc6's Avatar
owc6
No, I don't believe it does. It only turns off the interior motion detector, not the inclination sensor.
They are two different things. I'm not sure you can even turn off the inclination sensor if the car is off and the alarm is set.
Old Sep 17, 2016 | 12:05 AM
vbdenny's Avatar
vbdenny
I have hit that a few time trying to open the trunk. Have been meaning to look it up but ahh, the manual is thick. Although I knew there is an alarm, I had no idea it was so high tech. Of course I generally dont let my wife and not many passengers either I have yet to set of the alarm. Im guessing there is no exterior point you can touch to lock the car or open the trunk?
To Motion Sensor Question
