Winter storage, no plug-in available
Just unhook the negative terminal and charge in the spring.
Sorry, can't agree with that. 15 minutes isn't enough to both charge and help the engine. You need to actually drive the car and get all fluids up to operating temperature. Also, 30 - 40 minutes at minimum would be needed to adequately charge the battery. Probably closer to an hour.
Moderator emeritus
2015 C7 of the Year Finalist
I had a "toy" that I only took to car shows. When it was in storage, I removed the battery, brought it home and put the battery on a maintainer. When I want to use the car, reinstalled the totally fully charged battery and drove the car away.
Elmer
Elmer
One thing to note if you do disconnect the battery is you have to "index" the windows by putting em down and back up. Convertible has a little procedure too. After you do the windows, you hold the vert button up till the windows roll down and it beeps. The second one took me a little while to figure out the first time I disconnected the batt. Not very clear in the manual.
get a battery jump starter with a 110 V output. Plug the battery tender into it. once a week or so recharge the battery tender. use a volt meter to check the car battery and jump start voltage.
I live here in VA - much farther south than NY, but still susceptible to significant snowfall. When I get my new C7 (which I hope to be ordering in December), it is going to be a 'garage queen' and in no way will I be tempted to drive it in any type of inclement weather.
As for the battery sitting during winter, I would recommend disconnecting the negative terminal if the car will be stationary awhile. Even in NY, you should still be able to drive it once every couple of weeks. Plenty of sunny (albet cold) days with no snow.
I wonder if the Corvette - with all of its electronic wizardry - drains the battery any faster than a "normal" car does when not driven for long periods of time.
It's no worse than any other contemporary car. Even entry-level KIAs have a lot electronics these days. It's always been a problem with garage queens of all makes and models.
None of my cars are garage queens, and the C7 will be driven all winter in Maryland.
Disconnecting the negative cable is generally sufficient but the reason I recommended considering removing the battery in my earlier post is some people will be storing their vehicle for the entire winter in an unheated space. Even disconnected a battery will slowly self-discharge if not on a maintainer and this will also increase the temperature at which the electrolyte will freeze. If a battery does freeze and crack and it isn't discovered until Spring then the highly corrosive electrolyte will have made a large mess.
It isn't as much concern for a car that won't see well below freezing conditions in storage but if that is a possibility for your car then I would remove the battery.
From: Suppliers of dirty oil for 50 years Oilberta/ In Mex enjoying the winter.
St. Jude Donor '11
Bill
