I've seen pictures on this forum of a C7 with the entire side of the car jacked up using the front side jack point. Question I have is whether this can be done using the rear, side jack point.
F/R side pucks no problem
on all 4 stands in 2 minutes with 1 lift per side
Jake:
Your's are the pictures I have saved. What I want to be able to do is jack the car so I can put jack stands (flat topped) at the factory jack points on the sides. If, for example, I was raising the front for an oil change, I would jack at the rear factory jack point and slip the jack stand under the front factory jack point. I know I could jack the front sides from under the suspension points but just don't care for the idea.
