De-badging ?s
Old Oct 11, 2016 | 10:10 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
Default De-badging ?s
I've read where you guys have used heat or WD40 or goo gone...all with some fishing line.
Just saw a video with 3M adhesive remover. Anyone use this also? Looked like it worked great.
I'm just swapping out to carbon flash badges.
Old Oct 11, 2016 | 10:16 PM
See 8's Avatar
See 8
I used dental floss and goof off and it worked great with little effort.
Old Oct 11, 2016 | 10:57 PM
Maxpowers's Avatar
Maxpowers
Hair dryer and goo gone for me. At the end of the day pretty much all methods work.
Old Oct 11, 2016 | 11:26 PM
nyciti's Avatar
nyciti
Dental floss works, none of that waxed stuff tho. I prefer welding wire, not hard just take your time go slow. I removed the fish and the rear lettering. To get the sticky stuff off I used acetone and water.
Old Oct 12, 2016 | 01:03 AM
Kraz8s's Avatar
Kraz8s
Dryer and goo-gone for me too. You can treat each badge for a few days with it, then hit them with the dryer and they should fall right off.
Old Oct 12, 2016 | 07:10 AM
RipcordZ51's Avatar
RipcordZ51
I tried it all and had no luck and a sore thumb until I tried WD40. Just so easy after that.
Old Oct 12, 2016 | 04:25 PM
NewfieC5's Avatar
NewfieC5
Soak with wd40 and let sit for 30 min. I sprayed again and let sit another 10 min but cooler temps here now, you probably won't need to. Read this in another thread after I struggled with the first 2. Made the rest of them much easier!
To De-badging ?s
