Will this be the 2018 LT1?
Part No.
19355378
535 hp @ 6300 rpm
Dyno and Tech Specs
THE MOST TECHNOLOGICALLY ADVANCED CHEVY PERFORMANCE BLOCK
Chevrolet Performance engineers have wasted no time digging into the new LT engine family to mine more power – and they’ve delivered it in the LT376/535. It builds on the technologies and capability of the LT1 6.2L offered in the Corvette Stingray and Camaro SS. The result is an engine with 75 more horsepower than its LT1 predecessor.
The LT376/535 is architecturally similar to the LT1 and LS family of small-block engines, but with a unique block casting, cylinder head design, oiling system, and more. It retains the advanced technologies of the LT1, including Direct Injection to support an advanced combustion system to create a more than capable engine for your project.
By adding CNC-ported heads and our high-lift LT1 Hot Cam the LT376/535 delivers more naturally aspirated horsepower than its predecessors.
LT376/535 DYNO
LT376/535 TECH SPECS
Part Number:
19355378
Pistons (P/N right hand 12674094 and left hand 12674093):
Hypereutectic aluminum
Engine Type:
Gen V Small-Block V-8
Displacement (cu. in.):
376 (6.2L)
Bore x Stroke (in.):
4.062 x 3.622 (103.25 x 92 mm)
Block (P/N 12619171):
Cast aluminum with 6-bolt, cross-bolted main caps
Crankshaft (P/N 19303897):
Forged steel
Connecting Rods:
Forged powdered metal with specific machining
Camshaft Type (P/N 12642245):
Hydraulic roller (billet steel)
Valve Lift (in):
0.577” intake / 0.577” exhaust
Camshaft Duration (@.050 in.):
228° intake / 248° exhaust
Cylinder Heads (P/N 12646959):
Cast aluminum; CNC-ported with 58cc chambers
Valve Size (in.):
2.13 intake / 1.59 exhaust
Compression Ratio:
11.5:1
Recommended Fuel:
Premium
Maximum Recommended rpm:
6600
INSTALLATION NOTES
Direct bolt-in replacement for Corvette and Camaro originally equipped
with LT1 V8
Engine is shipped without exhaust manifolds. Production manifolds will
work, but engine performance is optimized with competition-style
exhaust headers
This configuration is available only with a wet sump oiling system
One of my favorite things about chevrolet is that they list all of their crate motors and dynos on the website.
