Setting code on screen lock
Old Nov 5, 2016 | 06:30 AM
syswayne's Avatar
syswayne
Default Setting code on screen lock
2016 C7 stingray just purchased and don't have Valet mode, I don't think. Salesman did put a code to lock the screen from going up and down abut I cannot find how to lock it. I read the manual and said to go to home screen and push settings. My home screen does not have settings. Then punch in code on keyboard only key board I have is on the cell phone settings. Give me detail on how to do this? Does the engine have to be started to do this? Running me nuts.
Thanks syswayne
Old Nov 5, 2016 | 07:58 AM
revilingfool's Avatar
revilingfool
go to the right it might not be on the first screen, then push and hold settings till you can move it back to the first screen if you like.
It is indeed under settings though.
Old Nov 5, 2016 | 08:56 AM
syswayne's Avatar
syswayne
Does the engine have to be running for most of the setting to work. When my is not running can see very little setting going to the right.
thanks please advise. Sure having a hard time with this.
Old Nov 5, 2016 | 09:08 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
On the home screen you need to swipe to the left (like a phone) to bring up the second screen of icons.
Old Nov 5, 2016 | 09:49 AM
RonC7's Avatar
RonC7
Wayne,
Some settings are not accessible (grayed out) if the engine is not running or vehicle is in maintenance mode.
To enter maintenance mode and have all systems active without starting the engine press and hold the start button for about 10 sec WITHOUT pressing the brake or clutch pedal. The systems will remain on until you press the start button again.
Maintenance mode is a great way to sit and explore all of the settings on the info screen and DIC without running the engine. Just be sure to cancel maint mode by pressing the start button or you can run down the battery.
All C7 have valet mode. If you don't have PDR the screen stays up, glove box locks, and the convertible top is disabled. If you have the PDR it can be set to record in valet mode.
Enjoy!
Ron
Old Nov 5, 2016 | 10:07 AM
syswayne's Avatar
syswayne
Originally Posted by RonC7
Wayne,
Enjoy!
Ron
I will try going to Tech football game will be back later and try. Thanks for all your help I have had 4 covettes in the past but this one is giving me a hard time or I am it.
Thanks again for all your help syswayne
Old Nov 5, 2016 | 09:09 PM
syswayne's Avatar
syswayne
I held down the settings and it just jumped over to just a few items but nothing on locking the screen to stay. My screen goes up and down but I cannot figure out how to find that place to put the code in.
I don't even see a key pad to punch it in. Something not right with this vet on what you are saying you have. I guess I will have to go to someone local to help me because I purchased this in Dallas and I live in Lubbock and I know Lubbock want help me on this? I have worked on this for hours trying to get it to open up. What screen are you talking about sliding? I cant get my to slide. Thanks for your help.
Old Nov 5, 2016 | 10:00 PM
RonC7's Avatar
RonC7
Wayne,
It is VALET in the settings.
From 2016 manual starting on pg 130
Personalization
Use the audio system controls to
access the personalization menus
for customizing vehicle features.
The following are all possible
personalization features. Depending
on the vehicle, some may not be
available.
Infotainment System Audio
System Controls
To access the
personalization menu:
1. Press SETTINGS on the Home
Page on the infotainment
system display.
2. Press the desired feature to
display a list of available
options.
3. Press to select the desired
feature setting.
4. Press o BACK on the
faceplate or press the Back
screen button to return to the
previous menu.
Personalization Menus
The following list of menu items may
be available:
. Time and Date
. Driving Mode
. Language (Language)
. Valet Mode
. Radio
. Vehicle
. Bluetooth
. Apple CarPlay
. Android Auto
. Voice
. Display
. Rear Camera
. Return to Factory Settings
. Software Information
Each menu is detailed in the
following information.
Time and Date
Manually set the time and date. See
Clock 0 94.
Valet Mode (If Equipped)
This will lock the infotainment
system and steering wheel controls.
It may also limit access to vehicle
storage locations (if equipped).
To enable valet mode:
1. Enter a four-digit code on the
keypad.
2. Select Enter to go to the
confirmation screen.
3. Re-enter the four-digit code.
Press LOCK or UNLOCK to lock or
unlock the system. Press Back to go
back to the previous menu.
I've only used valet once to prove it works. This seems vaguely familiar.
Ron
Old Nov 6, 2016 | 11:41 AM
syswayne's Avatar
syswayne
Wayne,
Personalization
available.
System Controls
To access the
system display.
options.
feature setting.
previous menu.
be available:
. Time and Date
. Driving Mode
. Valet Mode
. Radio
. Vehicle
. Bluetooth
. Apple CarPlay
. Android Auto
. Voice
. Display
. Rear Camera
Time and Date
Clock 0 94.
keypad.
Ron
I can not get hardly get anything to come up when I select settings. I must not have valet, but the salesman put the code in for my screen to unlock on moving up and down before I left Dallas. Going batty over this, you have spent so much time with me and really thank you so much. I know I am old, but have good education and experience with lot of cars, but I cannot figure this out. Sorry, thanks again.
Old Nov 6, 2016 | 11:50 AM
syswayne's Avatar
syswayne
Wayne,
Personalization
available.
System Controls
To access the
system display.
options.
feature setting.
previous menu.
be available:
. Time and Date
. Driving Mode
. Valet Mode
. Radio
. Vehicle
. Bluetooth
. Apple CarPlay
. Android Auto
. Voice
. Display
. Rear Camera
Time and Date
Clock 0 94.
keypad.
Ron
Before I left Dallas with the Vette the salesman set the code for the screen to go up or down. Can you do this without the Valet Mode? And if so can you tell me how to do that? thanks again.
Old Nov 6, 2016 | 11:54 AM
RonC7's Avatar
RonC7
Does your screen go up and down with the SCREEN button? Is the glove box unlocked?
If so, you are not in valet mode.
The strange thing about valet is that you choose a lock code every time you use valet and need to enter it, confirm, enter it again, then press lock. There is not a lock code that stays with the car.
Try with the motor running to see if all of these choices are present in you car's settings. Android auto may not be there if you have and early 2016 and of course no PDR if you don't have it.
Old Nov 6, 2016 | 12:10 PM
syswayne's Avatar
syswayne
Yes screen goes up and down and glove box unlocked. How do I enter a new code each time?
Old Nov 6, 2016 | 12:28 PM
RonC7's Avatar
RonC7
Check your pm. I sent you my phone num. Call me
Old Nov 6, 2016 | 12:38 PM
syswayne's Avatar
syswayne
Finally figured it out. Sorry for so much trouble you are great person to text to on the forum. Thanks again 77 years old and still learning. I do not have valet. Thanks you so much syswayne. new owner.
Old Nov 6, 2016 | 12:52 PM
RonC7's Avatar
RonC7
Wayne,
OK, glad you figured it out. There are a bunch of settings to look at if you are so motivated. It's part of the fun! I've had the car 2 1/2 yr and still run across something new once in a while. I just reset the time in 4 cars and of course they are all different!
I'm also retired, but a bit younger than you are.
Be safe and enjoy the new car!
Ron
To Setting code on screen lock
