Is this normal?
Old Nov 6, 2016 | 09:39 AM
mrclean1's Avatar
mrclean1
Default Is this normal?
Yesterday on a 60 mile run on a relatively flat highway I noticed the tach wavering up and down 100 RPM, could actually feel and hear it. thought it might be me, so then engaged the cruise control, with the same result.
With the best 50 mile mileage screen I notice it bumps up and down 2 bars with the tach. It's a Z51 with 22K miles and I've never noticed it before. It needs an oil change in the next 2 weeks, along with the software for the airbag recall, should I have the dealer looking for something? Thanks
Old Nov 6, 2016 | 09:41 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I've nevertheless had that. Why not have the dealer check it out since you are taking it in anyway?
Old Nov 6, 2016 | 09:51 AM
bjones7131's Avatar
bjones7131
Sounds like torque converter that has been well documented on this forum as having problems. Do a search and I believe that is the symptoms.
Old Nov 6, 2016 | 09:54 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
You don't mention it in your OP, but do you have the A8? If so, that is a dreaded symptom of the Torque convertor going bad. If you have a 2015 and it's an early year model, I would go to the dealer with that symptom. 22K sounds like a '15.
Elmer
Old Nov 6, 2016 | 09:56 AM
mrclean1's Avatar
mrclean1
I tried to search the symptoms but couldn't find anything, was wondering that myself, but it performs flawlessly otherwise. Smooth clean shifts, no shuddering or anything like that whether running in manual or automatic modes. Maybe a hard shift or two when cold but otherwise good.
Old Nov 6, 2016 | 09:58 AM
mrclean1's Avatar
mrclean1
Elmer
Yes, sorry, it is a '15 A8 produced in March of 2015.
Old Nov 6, 2016 | 09:59 AM
eboggs_jkvl
Moderator emeritus
Ok, look at #1 symptom in this thread.
https://www.corvetteforum.com/forums...post1591430505
Elmer
Old Nov 6, 2016 | 10:13 AM
joemessman's Avatar
joemessman
Sounds like this applies to you and the fix in almost all cases is a new torque converter.
PIP5337E:
And here is a link to all you need to know:
http://gm.oemdtc.com/6597/pip5337e-s...-chevrolet-gmc
Old Nov 6, 2016 | 12:30 PM
rogergcam's Avatar
rogergcam
Default Not normal
This was exactly the first sign I had that my T/C was failing. I have a post someplace here that tells the whole tale of woe!
Long story short my local dealer and GM stood behind it. If you want the whole story PM me, and Ill give u my phone number and Ill give you all the details!
To Is this normal?
