Splitter install question
Old Nov 8, 2016 | 03:45 PM
Gary2016's Avatar
Gary2016
Default Splitter install question
I am aboput to install the poverty splitter on my Z51 and I saw mention of push pins to use instead of rivets. Does anyone have a GM part number for the pins? I am trying to locate them for my install. I believe you need 5? Thank you
Old Nov 8, 2016 | 03:53 PM
C8Jake's Avatar
C8Jake
10 holes
Old Nov 8, 2016 | 03:59 PM
Supersonic 427's Avatar
Supersonic 427
You need 10. No part # needed, just get the size for the holes that you are drilling. You can pick them up at Autozone or any auto parts store. I used 1/4" plastic rivets, but push pins would also be fine!
Old Nov 8, 2016 | 04:04 PM
Gary2016's Avatar
Gary2016
So if you used 10 does that mean you didnt use any of the existing screws? Sorry Im a bit confused is all. Thank you
Old Nov 8, 2016 | 04:06 PM
C8Jake's Avatar
C8Jake
also use existing screws
Old Nov 8, 2016 | 04:08 PM
Gio's C7's Avatar
Gio's C7
Old Nov 8, 2016 | 04:12 PM
Supersonic 427
The splitter has a total of 22 holes in it. You remove the 12 fasteners under the bumper cover then install the splitter with those same fasteners. The remaining holes (10) in the splitter are the one's you need to drill (like a template) to install the plastic rivets or push pins.
Old Nov 8, 2016 | 08:04 PM
TEXHAWK0's Avatar
TEXHAWK0
You might want to consider using the same screws that hold the bumper cover. A little more secure than plastic rivets. You can reach the inside of the bumper on all but the center two holes, so you can use the plastic rivets there.
I used the same U-nuts that hold the bumper, but as regular nuts (not clipped on). You only need to drill a 1/8" hole for the screws versus 1/4" hole for the rivets. The extra holes are all along the leading edge of the splitter, and I think are important to keep it from sagging over time.
To Splitter install question
