Tire life
Old Dec 8, 2016 | 01:51 PM
joemessman's Avatar
joemessman
Mine were done after 15K
Old Dec 8, 2016 | 05:58 PM
OzarkCorvetteGuy's Avatar
OzarkCorvetteGuy
I haven't heard anyone say anything about living in a hotter climate which I'm guessing will shorten their life?
Old Dec 8, 2016 | 06:31 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I have 12k on my Pilot Super Sports and they look pretty good still. I'm hoping for 30k, but we'll see. I'd expect the stickier Pilot Sport Cup tires to last about 15k.
Old Dec 8, 2016 | 06:37 PM
jimmyb's Avatar
jimmyb
I just replaced my fronts (base suspension) at 13,000 miles, they maybe had another 1,000 miles but with winter (rain) coming...Rears are good, at least another 5K left in them I would guess. Tire life is based on so many variables.
Old Dec 8, 2016 | 06:44 PM
owc6's Avatar
owc6
35,000 on fronts, 45,000 on rears, and no, I don't drive like a little old grandma, just the opposite. I don't do burnouts, but I drive spiritedly enough that my lifetime mpg is only 18.
One thing I do, that most don't, is get very frequent alignments.
Old Dec 8, 2016 | 06:51 PM
Dogbrother's Avatar
Dogbrother
My 2013 G/S front tires lasted 11,000 then I changed to Michelins and get great wear out of the front and backs. Now with my Stingray it came with Michelins so I expect atleast 25K out of them. The only bummer is run flats are expensive in the G / S sizes. It cost 2500.00 for a set of 4
Old Dec 8, 2016 | 07:04 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I live in Florida. I've got 18K on them and they look great.
Elmer
Old Dec 12, 2016 | 11:47 AM
sharpseadog's Avatar
sharpseadog
Default Me too
Originally Posted by Duck Hunter
I live in the cooler climate of NW Washington, and have 20,000 miles on my 2015 Z51 tires. They look like they will easily last another 10-15,000.
Got over 30,000 miles on 2012 C6 tires, still had some miles left when I traded for 2015 Z51. Have 22,600 on this car and expect to get at least 30,000 out of them. Plan to go to the AS3+ when I replace these. 🦁
Old Dec 12, 2016 | 04:05 PM
Malum1's Avatar
Malum1
Default Tire Life
28,000 on my '14" Z51 OEMS.
Old Dec 12, 2016 | 11:17 PM
Emerald Eagle's Avatar
Emerald Eagle
2014 M7 Z51
Replaced the OE tires at 32k with cord showing on the inside of the fronts.
No track time, mostly long distance touring.
Old Dec 13, 2016 | 12:07 AM
4thC4at60's Avatar
4thC4at60
See my post - #6 on this thread
I've been driving Corvettes for 26 years, have amassed more than 600,000 miles on Corvettes - I get between 28,000 and 40,000 miles on tires, generally around 35,000....
My last C6 had 123,000 miles on it and had 30% brake pads left...
Old Dec 13, 2016 | 12:14 AM
owc6's Avatar
owc6
Somebody likes to downshift……..
Old Dec 13, 2016 | 12:30 AM
  #33
OL2yellr's Avatar
OL2yellr
Default Tire Wear
I've got just over 17K miles on my 15 Z-51 Vert. Tires still look like new. I have taken 2 road trips at ~ 3K each. Kinda surprised the backs look as good that they do.
Old Dec 13, 2016 | 08:53 AM
  #34
JoesC5's Avatar
JoesC5
I see where most of the replies are for the tires on either the base C7 or the C7 Z51. The OP asked about the tire life on the C7 Grand Sport. If the C7 Grand Sport is anything like the C6 Grand Sport(or the C6 Z06 which had the same tires as the C6 GS), tire life will definitely be shorter than the tire life of the narrower tires used on the base C7 and the Z51. In addition, the GS has a more aggressive alignment than the base C7 or the Z51, which can affect tire life.
It's a little to soon to see what the maximum tire life is on the 2017 GS.
Old Dec 13, 2016 | 09:16 AM
  #35
neogenesis's Avatar
neogenesis
2016 Z51 here. I only got to 191 miles before they were replaced. Of course, that was by choice 😂 They still look amazing for the record.
Old Dec 13, 2016 | 09:48 AM
  #36
Red C8 of Jax's Avatar
Red C8 of Jax
Mine have 23K and I should get another 10K. If you want to get the maximum mileage with any tire you need to maintain the proper air pressure and check it often.
Old Dec 13, 2016 | 10:23 AM
  #37
Richard Ames's Avatar
Richard Ames
Stock Z51 2015 Ordered Fronts from Tire Rack yesterday at 14000 miles. Down to wear bars on the inside. I do corner aggressively as I live in a rural area and get a lot of opportunities. I could take some caster out of the alignment and get another 5,000 from the fronts but would lose some handling.
Local Chevrolet dealer service representative stated that the average C7 customer are using two sets of front tires to one set of rears.
How you drive and alignment makes a huge difference.
To Tire life
Old Dec 13, 2016 | 10:59 AM
  #38
joemessman's Avatar
joemessman
When I mentioned mine were done at at 15K, that means down to 4/32 tread wear for me. I won't go below that.
Old Dec 13, 2016 | 11:07 AM
  #39
JoesC5's Avatar
JoesC5
So many variables that can affect tire life.
I have Bridgestone run flats on my C6 Z06 that were developed specifically for the C6 Z06.
I now have around 37,000 miles on them and have around 3/32" of tread left and the fronts and rears are wearing evenly and the same tread depth. I run a little less camber front and rear than what GM says to use(but still more camber than what a base or Z51 C7 has). My front camber is -0.9 degrees and rear camber is -0.6 degrees. Front and rear toe as close to zero as possible(-0.08 degrees front and -0.02 degrees rear) I run to 160+MPH with that alignment without any problems(solid as a rock) and also do the twisties without any problems. As you can see I'm getting excellent tire wear and the wear on the front is very close to wear on the rear.
Unlike what your dealer told you, my fronts are rears are wearing very nearly the same, and that's with wider tires and more aggressive alignment vs the base C7 or C7 Z51.
The GM alignment numbers are extremely broad for the Corvette, so a new corvette can have widely varying alignments and the same goes for re-alignments.
Best to take the car to a shop that does precision alignments and have them align the car to exact centerline numbers, not to a number that falls within the wide +/- tolerance used by GM.
Old Dec 13, 2016 | 04:03 PM
  #40
Corgidog1's Avatar
Corgidog1
I have 3600 on mine and I see no wear at all.
