2014 Lt1
Old Dec 14, 2016 | 11:34 AM
coffeegrinder's Avatar
coffeegrinder
6th Gear
Default 2014 Lt1
I am looking to purchase a 2014 corvette conv. I have looked at a lot of pictures of the LT1 engines, but can't figure out why the LT1 460 HP has the add oil port on the left bank of the engine and the 465 HP does not show the add oil port. I realize the 465 HP is accomplished with the Z51 package. Could someone enlighten me on this issue.
Old Dec 14, 2016 | 12:26 PM
n8dogg's Avatar
n8dogg
Z51 has a dry sump oil system. You fill the oil in a canister in the passenger rear portion of the engine bay.
Old Dec 14, 2016 | 06:34 PM
mpuzach's Avatar
mpuzach
2014s with the NPP dual-mode performance exhaust system have 460 hp and 465 ft./lbs. of torque, regardless of whether or not the car is a Z51. Those without have 455 hp and 460 ft. lbs. The 460 hp version uses the dry sump system while the 455 hp one does not. On 2014s, there was no relationship between Z51 and hp or oiling system.
Old Dec 15, 2016 | 11:15 AM
coffeegrinder
6th Gear
Thank you for the info: Why do they advertise the LT1 as 460 and 465Hp.
Old Dec 15, 2016 | 11:18 AM
mksz51's Avatar
mksz51
Someone is uninformed, lazy, or doesn't understand the difference between HP and torque.
Old Dec 15, 2016 | 11:27 AM
Kev4's Avatar
Kev4
i am looking to purchase a 2014 corvette conv. I have looked at a lot of pictures of the lt1 engines, but can't figure out why the lt1 460 hp has the add oil port on the left bank of the engine and the 465 hp does not show the add oil port. I realize the 465 hp is accomplished with the z51 package. Could someone enlighten me on this issue.
$40.000 USD. Vancouver Canada. 7 speed manual. 28K trouble free miles.
Old Dec 16, 2016 | 02:11 PM
coffeegrinder
6th Gear
Thank you for the info. It is equipped like I want, but I am looking for red.
Old Dec 16, 2016 | 02:20 PM
Spacewalker's Avatar
Spacewalker
I had a 2014 base stingray 3LT with NPP and no dry sump. 460HP
IMHO thats the way to go. I wish the Z06 did not force the dry sump. I don't like it.
Old Dec 16, 2016 | 03:01 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The NPP exhaust is supposed to add 5 to HP and Torque. Period.... Dry sump is not the reason for the HP/Torque difference.
So, W/O NPP 455 HP 460 Torque
with NPP 460 hp 465 Torque
Z51 doesn't mean squat for the HP. Z51 gives different gear ratios in the transmission and rear differential.
Elmer
Old Dec 16, 2016 | 03:54 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Why don't you like it?
Elmer
Old Dec 16, 2016 | 11:40 PM
Koufax's Avatar
Koufax
That's a great deal. Wish I could afford it. I'm just a lurker from the C5 forum. I'll be around in about 4 years looking to buy a car like that.
Old Dec 16, 2016 | 11:50 PM
Foosh's Avatar
Foosh
What you say in bold above is not accurate with regard to the oiling system. You're right that on the LT1 the extra 5 HP is just a function of the NPP equipage, according to GM, and that wet sump cars can also have NPP. However, all C7 Z51 models since the beginning have been dry sump, as have all Z06 and GS cars.
The purpose of the dry sump is for track use. Wet sump cars cornering under high-G loads with oil sloshing around can uncover the oil pickup in the oil pan (wet sump), which is not a good thing for engine health. Dry sump systems ensure that oil is always being consistently pumped throughout the engine regardless of G-loads.
Old Dec 17, 2016 | 12:50 AM
mpuzach's Avatar
mpuzach
Yup, you are correct. As a result of trying to type quickly I made an error. What I should have said was:
  • Z51s use dry sump and non-Z51s do not.
  • Cars with NPP have 460 hp / 465 ft. lbs of torque whereas cars without have 455 / 460 respectively.
  • It's the NPP that adds 5 to both hp and torque, not the dry sump.
Thank you for pointing out my error.
To 2014 Lt1
