Shift boot fell down (pic)
Old Feb 27, 2017 | 09:37 PM
Bmwmike's Avatar
Bmwmike
Default Shift boot fell down (pic)
Anyone know how i fix this? Is this repairable or is it in need of replacement? Thanks - Mike
Old Feb 27, 2017 | 10:01 PM
walleyejack's Avatar
walleyejack
same happ to mine, i just put a few dabs of crazy glue on it.
Old Feb 27, 2017 | 10:13 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
A few folks replacing the shift **** have reported this issue. On the last page of my PDF about installing a cue ball shift **** shows a picture one poster supplied to me: http://netwelding.com/Shift_Knob.pdf
You'll see his solution was to remove the ****, pop off the boot and then secure the boot with a piece of wire tightened in the groove you can see in your pic.
Old Feb 27, 2017 | 10:20 PM
Jmcdude's Avatar
Jmcdude
Video @ 1:20 shows how to detach shift boot, might help?
Old Feb 27, 2017 | 10:43 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Unfortunately, I think your best bet is going to be to turn the boot inside out then you can use a small zip tie to secure it to that ring. It's not that bad a job if you're inclined to try it. Otherwise you could crazy glue it I guess.
Old Feb 27, 2017 | 11:53 PM
Clspht's Avatar
Clspht
Yup... Take the panel off with the boot... Turn the boot inside out and resecure it to the locking ring with a zip tie... Mine was secured with a zip tie from the factory... If you need instructions for removing the trim and panel, go to the MGW Shifters site and watch their install videos.
Old Feb 28, 2017 | 10:26 AM
nyciti's Avatar
nyciti
It's actually attached with two little staples through the leather and into the ring. If you have a staple gun strong enough you can try that or the zip tie.
Old Feb 28, 2017 | 11:31 AM
Bmwmike's Avatar
Bmwmike
Thank you for the replies everyone. I do have a staple gun so I shall take it apart and make the repair. I considered getting the suede boot I feel it will look funny with the leather ****. Again thank you for the help and replys. - Mike
Old Feb 28, 2017 | 11:47 AM
mdiiulio's Avatar
mdiiulio
I don't know why nobody has said to take it to the dealer for a new one. Very few C7s are out of the 3 year/36k mile bumper to bumper, even late 2014s still have some time left. Call your dealer, ask for a new one. Worry about garage fixes after the warranty is up.
Old Feb 28, 2017 | 02:20 PM
Bmwmike's Avatar
Bmwmike
Warranty would cover it. However I am a service manager of a car dealer ship ( not Chevrolet ) and its like not wanting to eat at a restaurant after working there. I have a recall on my daily driver and I am still worried about bringing it to be done cause of what goes on in the dealer ships. If I can fix it easily I rather do that. I will give it a try. If I have trouble I will go the dealer.
Old Feb 28, 2017 | 02:26 PM
agapsdiver's Avatar
agapsdiver
I believe an o-ring is used by GM to trap the boot on the ring.
That's what I used anyway after I installed an MGW shifter and it works great.
Old Feb 28, 2017 | 02:28 PM
brooklync5's Avatar
brooklync5
I wouldn't bother taking the car in for service for something like this. A dab of gorilla glue will hold that thing in place forever and you'll never have to worry about it again.
Old Mar 1, 2017 | 12:47 AM
Always Red Dave's Avatar
Always Red Dave
Off to the dealer for a BRAND NEW BOOT I say!
Old Mar 1, 2017 | 08:53 AM
John Micheal Henry's Avatar
John Micheal Henry
This and it would be a good time to install that MGW shifter..
Old Mar 1, 2017 | 09:17 AM
walleyejack
waste of time and gas going to a dealer.
Old Mar 1, 2017 | 09:20 AM
Bmwmike's Avatar
Bmwmike
You are right. That's why I ordered it already.
Old Mar 1, 2017 | 05:01 PM
dprestidge's Avatar
dprestidge
That o-ring goes between the ring and ****. Doesn't have anything to do with holding the boot to the ring.
To Shift boot fell down (pic)
Old Mar 1, 2017 | 05:16 PM
agapsdiver's Avatar
agapsdiver
Wrong, the o-ring is inside the boot, trapping it against the ring.
.......boot boot..........ring
....boot..........boot....ring
boot..... .(o-ring)boot..ring indent
boot.............boot....ring
boot
boot
boot
boot
Old Mar 1, 2017 | 05:27 PM
dprestidge's Avatar
dprestidge
boot
boot
boot
boot
I'd like to see a picture of that. Mine had no o-ring it had two staples. The o-rings came with the new ****, two thicknesses. To keep the vibrations down.
Old Mar 5, 2017 | 12:54 PM
agapsdiver's Avatar
agapsdiver
Here ya go:
