Rev matching
I find that RM helps me a lot when the car is cold and I'm shifting/driving normally until the car warms up. The times I don't have it on and I shift, I feel like I waited too long to shift and causes the car to jerk. The reason I'm shifting slower is so that I don't grind the gears, but the RPMs drop very fast when shifting slower. This is why I love RM when the car is cold also.
If you don't ever downshift a manual you don't know how to drive a manual. Even modern automatics downshift to be in a proper gear.
And it does work in "cold temperatures." The manual says it's disabled when the engine coolant temperature is below 32şF, which is only true for a few minutes after starting the engine when very cold. Even in frigid temps, the engine coolant temp get's up to 190ş plus within about 5-8 miles.
"Active Rev Match
Vehicles equipped with a manual
transmission have Active Rev Match
(ARM). ARM aids in smoother
shifting by matching the engine
speed to the next selected gear. By
monitoring shift lever and clutch
operation, ARM adjusts engine
speed to match a calibrated value
based on gear selection. On
upshifts and downshifts, engine
speed will be increased and
decreased to match vehicle road
speed and transmission gear
position. ARM is maintained for a
few seconds between shifts, then
deactivates if the shift is not
completed."
http://www.chevrolet.com/content/dam...ers-manual.pdf
If you don't ever downshift a manual you don't know how to drive a manual. Even an automatic downshifts to be in a proper gear.
Mine works at 30 below.
If coming to a stop from 70, or just dropping to a 30 mile zone, I push in the clutch, shift to neutral, and let it coast - apply some brake to slow down. If I come to a stop, I wait for the light, put the car in 1st and go. If I am just slowing down, I get to the appropriate speed, then apply some gas to get the engine revving to the appropriate RPMs and let out the clutch.
I keep an eye on my speed so if I need to make a sudden change, I know what gear I should be in and am ready to shift and apply gas. True, it may not be as quick, but I willing to take the risk. If I am coming down a steep hill I will leave the car is a lower gear and let the engine keep the car from reaching high speeds instead of riding the brakes, so I definitely can see usefulness.
It seems like a waste of gas and added wear to the car to shift and have sudden rev ups just so I can come to stop.
Automatics downshift because they have too. They don't know your thoughts or the situation; are you tapping the brake pedal, are you coming to a full stop, or just slowing down some.
But as long as it doesn't hurt the car, I don't know why anyone can say its wrong; just maybe not standard.
Unlike the paddles on your A8, which allow you to manually change gears, the paddles on an M7 are for turning "auto rev match" on and off. It's for matching engine flywheel speed to clutch disc (which you don't have) speed during a downshift on a manual transmission. Without auto rev match, or with it turned off, you have to manually blip the throttle with your foot during a downshift shift to do the same thing.
All of that is irrelevant in an automatic because it does everything for you.
