Michelin Pilot Super Sport tread compound - Run Flat versus Non-Run Flat
#41
Yes, I was wondering if it was the tire size or the composition (brand) that made one set of non-ZF tires bad and the other good.
The list I posted is the size and brand of the tires I am considering, with the diameter and tread width and rim sizes recommended. I've had good luck with Pirelli slicks and BFG R1s, with the latter lasting 3x as long as the Pirellis with roughly the same lap times (on a P-car).
But to answer your question here are the specs for the tires
NT01's
Front: 275/35/18, 25.55" overall diameter, 10.91" overall width
Rear: 305/35/19, 26.42" overall diameter, 12.32" overall width
Pirelli Slicks
Front: 265/645/18, 25.39" overall diameter
Rear: 305/690/19, 27.17" overall diameter
#42
Well, my amateur analysis says it is tire specific rather than size specific. The Nitto has a pretty stiff side wall and the Pirelli doesn't, so I have no idea! The BFG R1s is more like the Nitto in construction. I haven't heard from anyone who has used BFG R1s on a C7, but I've heard no complaints about the Pirellis (other than the normal stuff one gets from those who buy take-offs).
Thanks for posting your experience. It is food for thought.
#43
BaylorCorvette,
How does the tread width and the tire diameter compare between the different tires? I ask because I'm trying to figure out the best 18" tire to go on my wheels for track. I have a ZO7, and this is what I am considering:
Sorry about the columns. I have retyped a few times, and it always reverts to this mess. But the info is in there.
brand tire size rim range tread width diameter
Cup2 285/30/19 19" 11.4 25.8
Pirelli 305/660/18 10"-11" 11.22 26.3
Pirelli 305/645/18 10.5"-11.5" 11.22 25.75
R1S 315/30/18 10.5"-11.5" 12.1 25.5
R1S 285/30/18 10"-11" 11.3 24.9
TOYO 305/35-18 10'-12" 11.7 26.3
TOYO 285/30/18 9.5"-10.5" 11.7 26.3
Cup2 335/25/20 20" 13.1 26.6
Pirelli 315/680/18 11.6 27.5
Pirelli 325/660/18 11.5"-12.5" 11.81 26.3
R1S 335/30/18 12"-13" 13.2 25.7
TOYO 335/30/18 11.5"-12.5" 12.6 26
305/645/18
325/660/18
Years ago I ran the BFG R1s on my C5 and C6Z and loved them. I was always surprised more people didn't run them. Seems like I was the only one on any given track day. I didn't think they made the R1 in an 18" that would work on the C7Z.
I just checked R1 sizing and it looks like the best sizing option they offer which should work isbelow. I see you posted the R1S sizing. Those are not an option for me as they're an autocross tire and I typically run 40 - 42 minute sessions (i.e., a full tank of fuel/session). I think the R1S would be toast by lunchtime. Similar to Hoosier R and A. The R works well on track but the A is their autocross tire which can't be run for full sessions with any longevity.
285/30/18
335/30/18
I only wish the 335 sidewall wasn't a 30 series. Might have to order a set....
EDIT: Well hell, BFG tells me the R1 in 335/30/18 is discontinued. They still make the R1S in that size but they would melt if you ran them for any length of time. Too bad, you got me all excited as I really liked those tires.
#44
MPSS ZP 285/30r20 - 11.2" tread width.
MPS4S 285/30r20 - 9.8" tread width.
MPSS 285/30r20 - ~10.0" tread width (4 different specs average ~10 and range 0.7")
I am running Hankook RS3 at 285/35r20 - 10" tread width. Tires should be stickier than the MPSS ZPs but they are definitely softer and wobblier and I am consistently 1 second behind my track time on 15k miles and 4 track days MPSS ZPs. This is on brand new RS3s and even after 5k miles (same time really, within .10 seconds of when they were new). Now is this because the softer turn in? higher ride height? or narrower tread width? I am willing to bet the tread width is the biggest culprit. That's a 10% reduction in tire width on all 4 corners.
What I've also found is that there is a huge jump in tread width from the 285 to 295 on the MPSS non-runflat. From 10" to 11.5" average. But from 295 to 305 to 315 there is virtually no change in tread width. The actual tire width continues to grow but the tread width remains fairly constant at 11.5". Then another big jump at 325 to 13" and stays constant to 345. The overall tire width rises at an expected 0.4-0.5" (10 mm is 0.4") . This is all on tire rack's measurements which uses a curved ruler thing.
On the MPS4S. 265>285 only goes from 9.6"-10", 295 is at 11" and grows properly at 0.4" intervals through 305 and on to 325.
In short, get 295 or 305 non-runflats to replace the 285 if you want to match tread size. Be careful with total tire width as the sidewalls are less vertical and bulge much more. The section width to tread width ratio is an interesting measurement to look at when checking for fitment.
#45
Great info! You wouldn't happen to still have that spreadsheet and can share? 😀
#46
I had a huge spreadsheet doing similar comparisons and 1 thing was clear: the run-flat corvette spec MPSS had 3/4" to 1" wider tire tread than same-sized non-runflat MPSS and other brands. There are several specifications of MPSS for different brands. i am willing to bet the run-of-the-mill MPSS is not nearly as good as the Star spec (BMW) or MO spec (mercedes) MPSS. For example for tire size:
#47
I couldn't find tread width on Michelin website nor how to determine if the tire was for a vette or BMW etc. Foosh has been convincing me that as3 plus ZP would give me wood but want to verify width and spec.
#48
I presume the OP is talking about a Z06? Can't find that info anywhere, the assumption seems to be we know what specific kind of C7 he owns.
#49
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
IMHO I think you had the answer it in your first post! The sidewall construction differences.
That has more to do with slip angle and the Michelins that come with the car have very low slip angles, more like a racing tire. IMO that is what causes the much higher "Chatter" when it's cold, more than tire width, size, Ackerman settings and tread compound.
My Z51 C6 had the same tire width and my Z51 C7 and no where near the chatter when backing out of my garage on a cold morning! My 3 week old Grand Sport will probably be worse when it gets cold again. Now, with warm weather I make a full look turn to go down the driveway after backing straight out of the garage and zero chatter. In the winter, with my 2014 Z51 had to make one or two K" turns or car would literally hop! May not have done any harm but felt bad!
Doubt you could get Michelin to discuss it!
#50
tread width is all on tire rack. If you google pilot super sport spec. Michelin website is one of the first. It is located on the sidewall. A * is BMW, MO is Mercedes, TPC is for GM cars, K1 is Ferrari.
Roadrogue (05-10-2017)
#51
I finally got to really push the 4S tires today. I didn't have any problems and they worked fine. Two things:
1. They didn't seem to be better the MPSS. Was running about the same times. Was my first day out though, so my brain was rusty.
2. They are definitely noisier than the MPSS. They really like screeching.
daleong (05-12-2017)
#52
