Purchased 2015 C7 6/2016. Found a crack in upper left corner (drivers side) of windshield on inside glass layer. Dealer had Safelight replace, all is OK. Placed car in storage 1st of Dec '16, Just brought car out of storage, found crack in windshield in same spot. Dealer has no explanations, Safelite is "researching the problem". Is this a common occurrence to have 2 cracked windshields in less than 10 months! My old C5 convertible didn't have these issues. Any insight or help would be appreciated.
Yes. Unfortunately somthing to do with a but in the surrounding are. Do a forum search. It will come up..Ahhhhhh GM.
Something hard is touching the glass and cracking it, maybe a rough seam that needed to be ground down, and wasn't at the factory. If the glass touches anything hard it will crack it eventually. Have them inspect the area closely before they put the next one in.
Mountainc7,
I had a crack on the passenger's side upper RIGHT corner on the inside. Dealer immediately recognized the problem and replaced it under warranty. A third party contractor replaced it within a week.
The third PC also stated it was a weld not properly ground before installation at the factory.
My car was about 10 months old and I was amazed how much debris, i.e., chips, nicks, rash the car picks up in a relatively short period of time. The good thing is you're getting a new windshield and your visibility will be like new.
Talked to dealerships today, 5/23/17 and they are denying any responsibility or liability for crack in replacement windshield they had installed 6/16. They claim that since GM has not acknowledged there this a design or manufacturing problem, there is nothing they can do for me. So I'm on my own in getting the windshield replaced and problem resolved. What a crock!
This is actually somewhat common. Definitely a GM problem, but why own up the problem when the owner of the car can pay for it instead of the dealer or GM?
Aren't you still under the bumper to bumper warranty?
Dealer told me glass only had a 12 month, 12k mile warranty. They also said that since my vehicle did not have the original GM windshield, it would not be cobered. They didn't care that they had the original w/s replaced by Safelite.
If they don't fix the problem with the welding slag you're just gonna keep having to replace the windshield. I'm sure the dealer knows the problem problem as does Safelight, so you either pay or go squeaky wheel. Windshields are expensive. If you gotta pay, I'd take it to a mom and pop windshield place that's not big corporate where they will be willing to grind off the slag so it doesn't keep happening. Good luck.
I might ask to talk to a district rep. on this. It seems hey did not take care of the underlying problem and that is why it cracked again. There have been many reports on her about windshields cracking in the identical area as yours.This is a issue that GM is well aware of. Your dealer has to go to bat for you and get GM to warranty this.
My windshield has a 3 inch crack on the inner glass at the top of the driver's side. No impact marks. Called my dealer and they said it was not within warranty and would not cover it. I mentioned the numerous complaints about this issue in this location. They suggested calling customer care. Has anyone tried this and were you successful in getting it fixed?
Mine was replaced under warranty no questions asked. It is not an uncommon issue. If your general car warranty is still in effect you are golden.
The tech inspector at the NCM HPDE at VIR on 24 June told me i had a 10-inch long crack in the driver's side windshield. I had never noticed it. Since it was in the tinted area about 2 inches from and parallel to the roof line, the tech inspector told me "no problem". If it had been lower than the tinted area, I would've failed tech inspection!! I took the car to the Chevrolet dealership, who inspected it for rock strikes or some clear reason for the long crack. There was no evidence of anything striking the windshield. Since I am out of warranty, they said they'd split the cost with me.
Try another dealer, mine was replaced by dealer under warranty!!!!
OP, my crack was in the same location and the dealer replaced my windshield under warranty no questions asked. That's been 2 years ago and no reoccurrence. Try another dealer.
I called customer care and they just circled back to the dealership. Another member of our Corvette club has an identical crack on his windshield and his car is a 2016. Both are 3-4 inches long, in the upper corner on the driver's side. If I overlaid the photos of each car you would not be able to distinguish the difference. Both are cracks on the interior layer of glass only. The outer layer is not cracked. He has a 10 year bumper to bumper warranty so he believes his will be replaced at no cost. I am unwilling to take it to a dealership just to have them charge me for what is clearly a defect in manufacturing. Is anyone keeping a log of these problems similar to what was done with the torque converters?
This is a known issue. Mine has been replaced twice all under warranty. Had to do with the locator tabs that locate the windshield when it is installed on the assembly line. Recommendation from GM was to cut off the tabs when installing by hand. It has nothing to do with temps, speed or loads of any kind. Warranty job.
Thank you. Was there a bulletin issued from GM on this? It always helps to be prepared.
I don't believe there was. But they replaced mine no questions asked. By the second time around they had figured out it was the tabs creating the problem. If the tab was out of place when they inserted the windshield it could cause the issue.
