Water filter
Old Apr 8, 2017 | 04:09 PM
Jcaroglani's Avatar
Jcaroglani
St. Jude Donor '17-'18-'19-'20
Default Water filter
What water filters do you use for washing your car?
Old Apr 8, 2017 | 04:29 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
None, water comes out of the tap...
Old Apr 8, 2017 | 05:36 PM
Patches's Avatar
Patches
Our water here is HEAVILY laden with minerals that leave a chalky residue on the car if you rinse and let dry. Even drying as quickly as possible, it will leave permanent water spots that require clay-barring to remove. With this system, I can let it air-dry and it is virtually spot free, although, I use the Master Blaster to blow all the water off.
Old Apr 9, 2017 | 03:50 AM
Jcaroglani's Avatar
Jcaroglani
Thanks! That is what I'm looking for. I guess I didn't notice the hard water spots on my white truck but they really show up on my black vette
Old Apr 9, 2017 | 09:58 AM
Foosh's Avatar
Foosh
Initially, I was skeptical, but I've become fan of CR Spotless systems. I have the same unit as pictured above, except it's mounted on a cart w/ wheels so I can use it anywhere.
I don't care what kind of water you have, it will have dissolved solids, and that's what causes spots. How badly things spot when water dries depends upon the total dissolved solids (TDS), which are the total amount of mobile charged ions, including minerals, salts or metals dissolved in a given volume of water, expressed in units of mg per unit volume of water (mg/L), also referred to as parts per million (ppm). TDS is directly related to the purity of water.
My home's total TDS count is 161, which is pretty good for well water, and the water coming out of the CR Spotless is 0 until the resin is depleted. Once you reach a TDS count of 20, you'll start seeing water spots. With my count of 161, I can produce about 500 gallons of completely pure water until the next resin change.
I use it with a 1.2 gpm power washer, which means a lot of washes. We have 5 vehicles, including a 45 ft. motor coach, as well as a lot of windows in our home, so there is a lot of washing to do.
The bottom line is that I can use the CR Spotless unit, walk away without drying, and there will literally be zero water spots.
Old Apr 9, 2017 | 10:20 AM
VistaVette's Avatar
VistaVette
Thanks for posting the info on the CR unit. I have really hard water in Las Vegas so I don't dare wash my car or Harley with the hose. It's a slow bucket with water and two towel method- wipe and quickly dry. I think I'll invest in one of these. Skipping 10 professional washes pays for it.
To Water filter
