Sideways
Old Apr 11, 2017 | 08:35 AM
don01's Avatar
don01
Cruising
Default Sideways
new lt1 with auto trans and mrs .with traction control off and in tour mode car goes sideways on heavy acceleration..Is there any low cost srpension I can add to help . z51 suspension stuff.
the old man of 70 thanks again
Old Apr 11, 2017 | 08:46 AM
NSC5's Avatar
NSC5
Don,
Best to leave traction control on! I am not sure where you are located but the tires do not have good traction until they are very warm. 65 degree ambient temperature still results in tires that will slip easily since the compound used for these tires is appropriately called extreme summer performance. You also have a lot of torque down low with the LT1 and an automatic with an extremely low first gear plus the torque multiplication provided by the torque converter and this combination makes it very easy to break the tires loose.
In my 2014 Cadillac ATS with its 321 HP V6 I can treat the throttle like an on off switch going instantly to full throttle with nothing bad happening as long as the tires have decent traction. If I tried that same behavior in my 2016 Z06 I would be sitting in the corn field waiting for a tow truck. At low speed and particularly with tires that aren't up to full temperature you have to roll into the throttle.
Old Apr 11, 2017 | 09:09 AM
kenownr's Avatar
kenownr
Don, NSC5 is correct on all points; leave the traction control and ALL the nannies ON until you get used to the car. Don't take a trip into the corn field
Old Apr 11, 2017 | 09:28 AM
dvilin's Avatar
dvilin
Old Apr 11, 2017 | 09:29 AM
Groovepusher Sly's Avatar
Groovepusher Sly
The manual has a section on Competitive Driving Mode, I read it frequently.
Sly
Old Apr 11, 2017 | 09:34 AM
Hopper12's Avatar
Hopper12
Don, NCS5 and Ken are right on. For your sake, the sake of those around you, and for your car - please don't turn all the nannies off unless you're in a private place with no cars around. It's clear from your post that you probably don't have a lot of experience (yet) with a rear wheel drive performance car with a ton of torque. Even those with a lot of experience get themselves into trouble. Get used to the car first, begin to experiment, have fun, but ALWAYS err on the side of safety when you're on public roads. It only takes once to ruin your day, and someone innocent bystander too.
Here's a vid clip of someone who took the nannies off. Z06, but the very same can happen with an LT1 if you don't have good conditions.
Old Apr 11, 2017 | 09:51 AM
Woodson's Avatar
Woodson
IF you really want traction control off, why would you be in Tour mode?
Old Apr 11, 2017 | 10:13 AM
don01's Avatar
don01
Cruising
a lot of very good info thanks a lot
Don
Old Apr 11, 2017 | 10:19 AM
NSC5's Avatar
NSC5
Don,
We are just trying to make sure you make it to 71 in one piece
Have fun but be safe.
Old Apr 11, 2017 | 10:26 AM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Some of us paid money to have a car that does that...
Old Apr 11, 2017 | 01:31 PM
Eff A Ford's Avatar
Eff A Ford
That's what it's supposed to do.
Old Apr 11, 2017 | 01:49 PM
Scruff Vette's Avatar
Scruff Vette
Old Apr 11, 2017 | 01:50 PM
Rebel Yell's Avatar
Rebel Yell
Originally Posted by NSC5
Don,
I have found that if you turn the traction control off you're going to need a 40 acre parking lot with nothing in it to hit.
Enjoy that car Don.
Old Apr 11, 2017 | 02:32 PM
Kent1999's Avatar
Kent1999
Agree with all the above. Keep the nannies turned ON when on the street. They do not reduce power unless you are already slipping.
The Stingray has more than enough power and a light enough weight to break the rear tires loose and get you sideways, even at 40+ MPH. And once it starts to let go, it goes QUICK.
Don't let your pride (or any of the idiots on the web) fool you into thinking "Bah! I'm a great driver and don't need the nannies!" Save those hero-style antics for the track where you have more runoff room and armco!
Enjoy and welcome to the Forum!
Old Apr 11, 2017 | 08:25 PM
Larry/car's Avatar
Larry/car
If you pay attention and control your power accordingly, you can feel when traction starts to lessen and the rear of the car starts to drift. Just a slight power reduction will correct drift without personel drama.
Old Apr 11, 2017 | 09:48 PM
ZMMMMM's Avatar
ZMMMMM
It sounds like you turned “traction control” off, but left “active handling” on. Active handling is designed to always point the car in the direction that you are steering it. So…if the car starts to fishtail, it should be automatically applying 1 or more wheel brakes as a correction.
In my old C6, I would turn TC off, but leave AH on…on a wet road…floor the throttle…and the wheels would spin, but the car would go straight. In my C7Z06, with ALL the nannies on, the car always seems to correct itself if it gets loose #YMMV
Old Apr 12, 2017 | 06:22 AM
lakemg's Avatar
lakemg
I have the solution for you...I will trade you my 2016 Cruze for your C7. It will be a win-win. You'll no longer have issues going sideways and I'll have two C7s....
To Sideways
