Shifter install
Old Apr 13, 2017 | 09:17 PM
mtaylor's Avatar
mtaylor
Default Shifter install
Did anyone who has done the shifter install have an issue getting the silver collar below shifter know to turn? Mine doesnt wany to budge.
Old Apr 13, 2017 | 09:58 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Are you lifting up while turning counterclockwise?
Here are the written instructions for that:
https://www.corvetteforum.com/forums...post1586574474
Old Apr 13, 2017 | 10:02 PM
mtaylor's Avatar
mtaylor
Yep, ive watched video and downloaded the pdf. Ill give it another try.
Old Apr 13, 2017 | 10:11 PM
TEXHAWK0's Avatar
TEXHAWK0
Here is the shape of the notch the chrome ring pin fits in.
Lift, twist to right
Old Apr 13, 2017 | 10:34 PM
mtaylor's Avatar
mtaylor
There really isnt any room for it to move upward.
Old Apr 13, 2017 | 10:39 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Is the boot detached fully from the ring? If it is, you should be able to just unscrew the shift **** then. I think.
Old Apr 13, 2017 | 10:41 PM
mtaylor's Avatar
mtaylor
On the c7 its its attached by bolt and you need to get the ring down to access it.
Old Apr 13, 2017 | 10:42 PM
SK360's Avatar
SK360
It needs pulled up on while you turn it, it doesn't look like it has enough space to pull up but it helps. Mine came off pretty easy.
Old Apr 13, 2017 | 10:43 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Damn, that's right. Geez, that's pretty snugged up there. Vice grips and gently twist maybe?
Old Apr 13, 2017 | 10:44 PM
mtaylor's Avatar
mtaylor
That might be next option just dont want to break the plastic
Old Apr 14, 2017 | 02:41 AM
mtaylor's Avatar
mtaylor
I ended up getting it off with a set of channel locks it was super easy to put back on. This process was a much bigger pain in the dick than I was anticipating and getting dust cover over the shifter about drove me insane.
Old Apr 14, 2017 | 05:11 AM
08G8V8's Avatar
08G8V8
Yep, I had the same issue with mine. I had to wrap it with a towel and use vice grips to twist it. The MGW videos make it look so easy, but I found out that is because it has already been removed before. Once you remove it the first time, it moves very easily as shown in the video.
Glad you figured it out.
Old Apr 14, 2017 | 09:06 AM
cheapthrills's Avatar
cheapthrills
Mine was a total bitch the first time, I needed channel locks as well. Now I can do it with 2 fingers pretty easily.
Old Apr 14, 2017 | 09:54 AM
mtaylor's Avatar
mtaylor
Yeah also broke one of the tabs on center console but doesnt really seen to have effected anything. If it does i guess install cost me 200
To Shifter install
