C7 plenum cover insert
Old Apr 20, 2017 | 09:49 PM
Mayhew46's Avatar
Mayhew46
1st Gear
Default C7 plenum cover insert
Has anyone purchased a painted plenum cover for C7 that just goes over the current plenum cover?
Old Apr 21, 2017 | 01:04 PM
Flame Red's Avatar
Flame Red
PM forum member fred1971 as he just bought and installed one. Initially, he was not pleased with it.
Old Apr 24, 2017 | 05:33 PM
ferd1971's Avatar
ferd1971
Just for clarification, I purchased the Plenum OVERLAY from RPI. It was painted very well and even had the 3M tape necessary to apply it. Once I installed it, the overlay actually popped up from the OEM plenum. It almost seemed like there was not enough 3 M tape to hold it down. I later discovered the plenum overlay was slightly warped in an upward direction. When I contact Don at RPI, he recommended waiting for the temps to reach above 70 degrees before applying and to make sure you clean the OEM plenum with alcohol. I went one step further...I bought more 3M tape and applied it to the overlay. When the weather got nice enough, I applied it and then laid a terry cloth towel on top of it. I also laid 20-30lbs of hand weights on the towel to hold the overlay in place. After about 1 week (you don't have to wait this long), I removed the weights and towel and the overlay was perfectly attached. Looks great now!
Your other option is to purchase a painted OEM plenum...It costs 2-3 times as much as the overlay and is attached using the OEM screws.
Old Apr 25, 2017 | 11:41 AM
bbrown450's Avatar
bbrown450
Ferd... can you snap a pic please
Old Apr 25, 2017 | 12:18 PM
ferd1971's Avatar
ferd1971
Here you go...
The before...showing the curvature of the Plenum overlay.
The after...showing the completed project (sorry, I don't know how to rotate the photo)
To C7 plenum cover insert
