Cooling fan fuse # on 2014 Corvette Stingray
What is the cooling fan fuse # on a 2014 Corvette Stingray, I can't seem to find it on the fuse cover. Is there a abbv. for it.
Moderator
Both the front and rear fuse blocks are listed in the Owners Manual (at least for 2014). Unfortunately none of them are labeled as the cooling fan.
Was able to download a manual for the 2014. Found the rear fuse panel but nothing is showing cooling or fan, even the fuse panel is not saying anything.
Thanks for the help.
I don't see a 80 amp. Highest is a 60 for the Anti-Lock Brake Pump, 2-40's and a 30 amp.
Putting a ProCharger on the car and they want you to disconnect the Fuel Pump and cooling fan. May have to just disconnect it at the fan.
Thanks!
Thanks!
The 80 amp cooling fan fuse is located in "X50B", which is the Aux Fuse Block, next to the large underhood fuse/relay box. Look at the white plastic forward pointing mounting arm of the engine coolant tank. Right next to that white arm, towards the fender, is a black plastic rectangular snap-on cover, about 3 inches long and maybe 1/2 inch wide. I think the 80A fuse is under this cover. I think it is Item 7 (the cover) in the diagram below.
That has 4 - power cable lugs, one for the main fuse block and I believe the other heavy cable goes to the starter ( can not see where it goes) and the two smaller cables run into different looms with the #5 & #6 stamped into the terminal lugs. There aren't any fuses located in that location.
Went to Chevy for more info. and yes that is the correct fuse panel. The cooling fan is X6. It's the the 2nd lug from the left. The cable lug is stamped w a #6 also.
I will try to upload a copy of GM's Document ID: 3396159 which shows it.
Thanks again for you help.
