Paint defect, new Z06
#81
Again. You can see by the look that it is a gap issue maybe there is very slight movement in the panels and since they are so close chipping begins to occure. If it was a paint spray problem defect in paint would never look like chipping. The key word here is CHIP
#82
The easiest (& correct) fix would be for GM to address the issue in the first place. It's clearly a gap issue with adjoining panels touching.
Seeing the pictures posted on this forum, it's blatantly obvious these cars should never be leaving the factory with that happening.
#83
Yep, I know from experience here. My dealer is currently working with Chevy HQ to see what is going on since they tried to fix it once and it only last 50 miles before peeling again. It seems these are starting to become more and more prevalent now, so hopefully GM has a good "fix" ready soon.
#84
#85
my car is super tight in all 4 of those areas. I have zero paint chipping there at 1400 miles. This is why I still believe it to be a prep issue. Paint is not adhering well enough so that tight gap is popping it. All 4 yrs have this issue.
#86
As far as "replacing" questions, that's pure wishful thinking. Dealers have their own body shops for a reason. Only in the rarest occasion will they get a part pre-painted, and an entire bumper doesn't fit the rarest occasion category.
#87
My gaps are super tight too. I wouldn't want gaps you could put a credit card in. I walked away from vette's that looked that way. I have 6500 miles with tight gaps and no issue. Also when you look at the photo of the gray car, look to the left and see the gap is tighter than where the paint peeling is happening.
#89
If it was a gap issue .. the paint would be coming off both panels .. it seems like it always comes off the bumper cover .. its a paint adhesion or curing issue. Plus .. the paint should be wearing through if it was a gap issue ... not sliding off like somebody put some paint stripper on it.
Does anyone know if the bumper covers are painted in-house or outsourced ??
JimNeedsC7 (05-23-2017)
#92
My DIY instincts kicked in today and I decided to try a quick fix with hopes of at least making an improvement in my paint flaw. Confidence in my painting prowess is high right now after bravely painting my garage recently, but try this at your own risk.
First, I carefully cleaned the gap around the chipped area with a single-edged razor blade. Then I masked a very narrow area around the gap with blue painter's tape, grabbed a can of Duplicolor Torch Red paint I had lying around, and sprayed a small amount in the cap (not the gap). I first tried a flat toothpick to apply some paint around the chips, but after doing it over twice I decided a round, more pointed toothpick would work better, which it did.
Fast forward about an hour and several more tries, I think I'm happy with the result. It isn't as flawless as right side but I would suggest it is better than before. BTW there is a gap around the chipped area, so the chips likely weren't caused by the fender and bumper making contact--that is unless those panels are moving while driving. Maybe the factory installer guiding the left-side panels wasn't as careful as the guy on the right.
I firmed up the paint with a hair drier and cleaned up the new gap with first the razor blade and then my fingernail, carefully pushing them into the gap. I didn't try masking a larger area and hitting that very small section with the spray can, but that might work, too--maybe better. Close up it isn't as pristine as the right side and wouldn't satisfy a hardcore perfectionist, but from a normal viewing distance you'd be pressed to see the imperfections. If you plan on getting a dealer to fix yours as a last resort I wouldn't suggest messing with it, though.
#93
Nice job. Is your car out of warranty? Was the dealer not able to fix it?
#94
No, it's a 2017. I wouldn't want a dealer body shop attempt to fix something this minor, especially if they had to repaint larger areas of the bumper and/or fender and potentially screw something else up. My philosophy is to let dealers touch my car as little as possible.
#95
Too bad it happened, but good job fixing it yourself. A couple other things people can do for adhesion is lightly sand and wash with some type of cleaning prep.
#96
I would be concerned that by trying to fix it yourself, that it somehow negatively impact it being covered under warranty, but that's just a guess, I have no idea.
Good luck with your fix, I hope it's permanent .
#97
I spoke with the owner of the body shop today and here's what they did:
He first tried to touch it up, but after it dried etc, it just didn't look great. So they removed the front fascia, sprayed color on the 2 chipped areas only, but sprayed clear on the entire fascia. He said it's the right way to do it, and it came out great. I'll find out tomorrow when I pick it up.
robertbruce (05-26-2017)
#98
btw- Paramus has been great through this entire process.
Thunder22 (05-26-2017)
#99
#100
