A8 problem?
Old May 15, 2017 | 08:32 PM
Bassman57's Avatar
Bassman57
Default A8 problem?
This morning I went to take my baby for a cruise an experienced a very weird occurrence. I have a 2016 Z51 that has right at 2000 miles. The car has been safely ensconced in my garage for 6 days and hasn't moved. Today I got in it and after a couple of minutes of idling I put it in gear and it wouldn't move, normally it will ease away but today it acted like it was bolted to the floor. I gave it a little gas and it made a loud clunk and then eased out of the garage. I put it in park again and back to drive and everything acted normal. I drove it around town for about an hour with multiple stops and with about 15 miles of highway driving and never had any other issues. Has anyone ever experienced anything like this after a vehicle has been sitting for a few days? Thanks for the replies!
Old May 15, 2017 | 08:40 PM
NSC5's Avatar
NSC5
Any chance you had washed it or driven in the rain before you parked? Sounds like a pad stuck to the caliper and the clunk you heard was the pad breaking loose. This can also happen with the rapid temperature fluctuations this time of year causing condensation on the rotors as the air heats up more rapidly than the metal mass causing moisture to form.
Old May 15, 2017 | 08:41 PM
RicK T's Avatar
RicK T
If you put it away soon after washing, without driving it awhile, then the brakes probably got rusted to the rotors. Common issue with many cars, not just Corvette.
Old May 15, 2017 | 08:47 PM
maxp's Avatar
maxp
Old May 15, 2017 | 09:35 PM
NSC5's Avatar
NSC5
And I should have said pad stuck to the rotor It has been a LONG day.
As Rick T noted this situation happens with many cars, not just the Corvette however the extra large braking system on the Corvette makes the issue more dramatic. I have never had a pad stick to the rotor in my Corvette but it did happen once with my GMC 2500HD pickup which also has very large disc brakes since it has a 9,200 pound GVWR which requires serious brakes. I was taking my German Shepherd in for her annual checkup and the bang from both rear brakes in the pickup coming free upset my normally pretty calm dog.
Old May 15, 2017 | 09:37 PM
budgreen3564's Avatar
budgreen3564
Parking brake on? It will pop it off and go
Old May 15, 2017 | 09:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Did you feel the transmission go into gear and the car not want to move, or did it sound/feel like it was still in Park?
There have been problems with "delayed engagement" on the A8, first movement of the day.
Old May 15, 2017 | 09:53 PM
Bassman57's Avatar
Bassman57
Thanks for the replies, I did put it away right after I washed it. Sounds like my worries were for nothing. I guess I'll have to take it for a short run before I put it away after washing.
Old May 15, 2017 | 10:15 PM
ddelallata's Avatar
ddelallata
Here you go.
http://www.corvetteactioncenter.com/...2017-1345.html
Old May 16, 2017 | 03:47 AM
KemahGT's Avatar
KemahGT
Yep. Stuck pads. I only circled my block once after the last wash and it still did it. Might have to break out the lawn blower next time.
This phenomenon broke a pad on the last car that I had that did it. Seems like high performance metallic brakes might be more prone.
To A8 problem?
