Performance Data Recorder with nav
I'm trying to decide if I want this option? Can it be that this Data
Recorder is that much better than the standard radio. Obviously
it does more than the standard radio, but 1900 dollars more?
Feedback appreciated.
The PDR is a video recorder that has nothing to do with any radio. It records front camera with overlays for a racetrack, speed, rpm, throttle position, brake position, steering wheel position. If you want a built in dash cam it will also do that.
If you don't drag race or track the car it likely is of little use to you.
The reason I said it might make the car easier to sell when you want to get rid of it is a number of people looking at used Z06s will be considering them as potential replacements for their earlier model Track Cars. That PDR is a great option to have in the car when you take it on track. Most of those people will walk away from a car without it since there are so many to choose from that do have it.
As for daily putt putting around town it isn't used. Although if you buy a large enough SD Card above 32 GB and reformat it to the FAT32 file format you could get days worth of recording time and be able to use it as a hidden dash cam. A 32GB FAT 32 card gets you around 755 minutes of recording time.
Bill
Do you plan to track the car??
It's great for drag or roadracing.There are other data-acquisition devices, but the PDR is really good!!
Even if you don't track it, you can take excellent video of scenic drives, or it can be used as a dash cam to take video during street driving to capture unfortunate events that might occur to help with insurance.
If you do use it to record track sessions, there's an application by Cosworth called the Toolbox that will do very good analysis of your track sessions - including lap time, G's, a bunch of stats to analyze corners, performance and health (coolant and oil temps, tire pressures and temps, etc., etc., etc).
Here's an example of a couple laps around a roadrace course, and you can see what just the video shows. Even more data is available with Toolbox:
It's great as a dash cam and there's different overlays for Performance use.The way it's listed, the option is for the PDR, but IMO it's about getting NAV.
I wanted NAV and PDR comes with it, I doubt it would be that much if the PDR was offered alone.
It's worth it to me
I disagree. I use my PDR as a dashcam. The only PITA is I have to manually turn it on.
Thanks.....
The HD dash cam I have loops/wraps according to the size of SD card has GPS on mount, and comes on when power is supplied......
Now, can someone please tell me where 12v plug might be that is turned off/on with ignition.....smile....
I'm happy I have it in my C7
Bill
