A8 Transmission failure tracking
#41
My 2015 is slow to get into gear after sitting overnight. Probably has the drain back problem but I was going to wait to see if other problems crop up.
My tach drifts ~50 RPM in V4 mode but I have no other symptoms.
I entered no failures because I don't really consider these "failures" at this point. Should either of these be considered failures within the intent of this spreadsheet?
#44
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
This may be a bit too complicated for me as I only do the basics with technology but as some recall my A8 trans. in my previously owned 2016 C7 Z06 with 6,200 miles on the clock had a complete catastrophic failure and I received a new trans. under warranty but no then sold my Z as this was certainly a buzz kill.
#45
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
I HAVE MY FINGERS CROSSED 2017 A8 Z06 102 miles so far.....
Secret237 (02-29-2020)
#47
#48
CF Senior Member
First of all, thank you for all the work you've already put into collecting and organizing this data. Hopefully your hard work pays off at some point with getting something tangible done by GM to rectify what is obviously more than a one-off problem with the A8.
Data spreadsheets are like internet forums - - i.e., they can quickly get out of hand. But at the risk of complicating things further, let me offer a few suggestions that you may want to incorporate into the spreadsheet:
1. In seems to me that A8 "issues" come in various forms. One is obviously TC failure and replacement. But there are other potentially related issues like: a) hard upshifting from 1st to 2nd, b) RPM volatility when in cruise control, c) "rubble strip" vibrations and noise at varying speeds and conditions, and finally d) complete TC and/or transmission failure, whatever the later may mean. Some may experience a) but nothing else. Others may experience more than one of the foregoing issues leading, ultimately, to d). Having this granularity of data, while a PITA to collect and organize, would really be helpful in trying to understand the scope and magnitude of A8 issues.
2. Thanks to the excellent interchange of useful information on this forum, I'm convinced that most, if not all, of the A8 issues are directly linked to the functioning of AFM - - the feature that switches the engine from V8 to V4. As a result, I NEVER let my engine utilize AFM. As most readers know, you can purchase after-market devices to defeat AFM or you can drive your vehicle in Manual mode, which is what I do. I think it would be useful to collect data via the spreadsheet that potentially demonstrates a correlation between drivers that let their vehicles go into V4 mode and the issues noted in #1 above.
#50
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Stickied
#51
I've updated the charts in the spreadsheets, if there are some views your interested let me know, please do not mess with the charts tab :-) I've restricted the permissions on the charts tab so only I can make changes to that at this point.
An updated view of the charts has been edited into the first post in the thread.
Keep the updates coming, I still have a little data cleanup to do as well.
Buzzfl (08-02-2017)
#54
Sooner or later there will be some criticism of how you are guiding (your) project, so expect that as a normal course of human nature. Everybody is an expert, but none of these experts are willing to help. Don't let it get to you! The vast silent majority out there are grateful someone like you stepped up.
Again, THANK YOU!
#55
No problem. And I have no worries of criticism, as long as it is constructive. I'm happy to evolve this as needed.
In fact I was first looking at this from a different perspective that I still think could be valuable to the collective but I just couldn't pull it together in my head.
My thinking was more along the lines of the sticky threads that pull together the FAQs/How-To's. But instead it would be one that would index in some standardized format all of the issues that people are reporting. Things like warbles, black infotainment screens, wheel clicking, transmission failures, etc.
Just a way to make finding the current or master threads on those issues and providing current summaries to make sure people could find the content.
If master threads could be assigned to an issue once it hits a certain level, and then those were indexed it would help. Even better would be to assign curators for each of those issues that could provide some trusted summaries in that index thread showing the current status of each in a standardized format.
Just not sure how to pull that together :-)
#56
My 2015 C7Z has 2k miles on it currently (bought 2 months ago used). I have a feeling that the A8 will fail soon. I have delayed engagement. Lately i've noticed that sometimes the car just goes out of gear and takes a second to get in gear. In the mean time, my RPM just climbs - much like if you clutch-in and hit the gas. Car is also shifts rough in manual mode. I am really confused if these symptoms are serious because it's been a long time since i drove a TC auto.
#57
Take it to the dealer, you have a warranty still. Search through the regional forums to find a good service department in your region. If there's a TC issue going on they should be able to diagnose.
#58
#59
A8
There have been a lot of threads around the A8 failures. There was also a Poll. Thought it might be good to create a Google Sheet to track this stuff, could be good for Ask Tadge at some point or some other way to get data to GM in regards to the failures.
Open to suggestions on structure, I can handle making those adjustments. But this sheet is open to all for editing, so if your Forum User name is not listed, you can add it. If it is listed, you can update your response if needed.
There is a chart tab as well that has some data based on the April Poll results, but this will update with new data of course.
REPEAT: BEFORE UPDATING THE SPREADSHEET: Please search for your user ID, if it is already there, update that row. If not, you can add yourself to the end.
Google Sheet
https://docs.google.com/spreadsheets...it?usp=sharing
Chart of data
Charts are in a tab on the spreadsheet. This image of the charts was updated June 15, 2017
Google Sheet
Chart of data
radiant (03-11-2023)
