Which driving mode to use?
By the way, one thing I do not like to change is the steering feel. This I lock on Sport for any mode. Glad they gave us the ability to do this!
And congrats on your Z06!
The different modes act different depending Manual or Auto, mag ride or not, then conditioned with Rev Matching on of off.
Each mode has its advantages and disadvantages, depending on traffic and weather conditions and how you drive.
My obersvations are based on M7, not A8
ECO is good for cruise control on a road trip. Drops out to 4cyl until you press the gas or clutch. A percentage of both throttle and steering input is ignored. IMHO, pretty much not worth the effort if you never make it out of 3rd gear - gotta be in 3rd before E kicks in..
Weather mode is appropriate for wet or cold, it makes the nannies more attentive, throttle and steering a bit more forgiving - important when the roads are slick or cold.
Touring is balance of all modes, and the default at power on.
S tightens up steering and throttle response, decreases the nannies attention.
Tr increases the sensitivity of steering and throttle, and makes the nannies less attentive. The car is more responsive to all inputs, but the nannies are napping, and may not be there to save you quite as quickly.
Completion mode effectively puts the nannies to sleep. (AH/TC off)
Rev Matching in traffic is not necessarily a good thing w/ M7, you are slowing down, but rev matches boosts RPM, so when you let out the clutch, the car wants to leap forward - not good in rush hour.
Above all:
Regardless of mode, you must respect the car, especially the Z06. It will put down so much HP so fast, you'll be doing donuts before you can blink. Plenty of videos out there of that happening.
In rain definitely use weather mode. With the wide tires hydroplaning easily occurs and weather mode helps a lot.
Also, they demonstrate why one should always drive in Weather mode if there's water on the road...
Now if it's raining significantly it's in Tr with PTM set to WET.
I thought it was just me.
