Backfire
Old Jun 13, 2017 | 06:12 PM
lhowe's Avatar
lhowe
4th Gear
Default Backfire
when accelerated hard got a backfire. I have been told this can happen with the c7- chevy dealer could not find anything wrong with it.
Old Jun 13, 2017 | 06:14 PM
joemessman's Avatar
joemessman
Happens with mine all the time when I WOT. I have an A8 and on every up shift it pops. I accentuated it with a Bolra Xpipe.
Old Jun 13, 2017 | 06:21 PM
vbdenny's Avatar
vbdenny
Yup, suppose to do that. A big part of the fun. I've had several compliments on that brap.
smajicek's Avatar
smajicek
Normal behavior, its there to protect the tranny
Old Jun 13, 2017 | 06:34 PM
Skidplate's Avatar
Skidplate
My 2015 Z51 used to do that when new, however, it no longer does. It seems to shift fine at WOT but no pop. I wonder how I can recover it?
Old Jun 13, 2017 | 06:39 PM
sTz's Avatar
sTz
I don't believe that I've every heard a "backfire," but it pops and burbles at times...
Old Jun 13, 2017 | 07:53 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
I can see someone thinking it is a backfire, or describing it as sounding akin to one, but it is not a backfire and is perfectly normal on hard acceleration and a quick 1-2 shift. Hope you didn't pay the dealer to check that out :-)
Old Jun 13, 2017 | 10:38 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Nothing wrong at all-open it up and enjoy it!
Old Jun 14, 2017 | 12:11 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I always thought it happens on deceleration.
Old Jun 14, 2017 | 12:15 AM
mountainears
That's a little different but similar, a little extra fuel firing off. If you're not getting it on acceleration on your 1-2 shift, you're not trying hard enough :-) And I think people have said it's more apparent with A8's, so if you have a M7 you may be missing out. I find that if you paddle shift it close to redline on the 1-2 shift it's nearly guaranteed...
Old Jun 14, 2017 | 01:50 AM
vettefever17's Avatar
vettefever17
Willing to bet this is from the fuel cutoff between shifts. I believe I read on a post back in 14' that it happens within 100 milliseconds. Probably runs a little rich when the ecm fuels to avoid being too lean after the shift then it hits the heated exhaust and pops from ignition.
Old Jun 14, 2017 | 08:13 AM
Prray's Avatar
Prray
Yup my 2017 Stingray does it too, normal and I love it!!!!
Old Jun 14, 2017 | 08:38 AM
Maxpowers's Avatar
Maxpowers
There are two different things being discussed here.
The OP is talking about backfire under hard acceleration. Mine never does this.
Snap crackle pops under deceleration is normal.
Old Jun 14, 2017 | 10:08 AM
JaxC7's Avatar
JaxC7
Mine does it on ever WOT shift. I also get the crackle and pops under high RPM lift-throttle deceleration.
Glorious!
Old Jun 14, 2017 | 12:45 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
From what I was told by a GM engineer it is a designed in feature that nano interrupts the power delivery .(I have a 15 auto) That results in a little torque burble that allows the trans to upshit faster. (FWIW it sounds dam good when it shifts) I have had friends hear it and say something wrong with your car. WRONG its running fine!
For your youngsters on here back in the late 60s they were experimenting with switches to do this "break" They built crash box 4 spd manual trans that had every other tooth removed from the synchronizer <SPL> gears and to shift with foot on the floor you hit the button and put the trans into the next gear using no clutch resulting in a super fast shift
Old Jun 14, 2017 | 01:01 PM
NSC5's Avatar
NSC5
As noted by others with an automatic the pop/snap/crackle through the exhaust is normal with a WOT shift at redline power is cut very briefly (through severely retarding ignition timing I believe) which allows much faster shift completion. This power cut isn't done with manual transmission equipped C7s. You will hear a similar (but extended in length) sound when PTM is engaged in Track mode and power is being limited accelerating out of a corner.
Old Jun 14, 2017 | 01:23 PM
Maxpowers's Avatar
Maxpowers
Ahhh.... I was a bit one sided in my response. I have a M7.
To Backfire
Old Jun 14, 2017 | 01:26 PM
ea327's Avatar
ea327
Banned Scam/Spammer
To me, it feels like it is hitting the rev limiter. What ever it is, I love it!
Old Jun 14, 2017 | 02:04 PM
maxp's Avatar
maxp
I'm probably in the minority here but I hate the WOT 1-2 shift backfire. It makes the vette sound like a farmtruck needing a tune.
Old Jun 14, 2017 | 02:26 PM
Panhead51's Avatar
Panhead51
I have the Borla x-pipe w/rear cats delete ....I would describe my "backfire" between gears on hard acceleration as a hard spit ..sounds great, luv it !!!!!
