Question about fluid changes
Old Jun 18, 2017 | 01:26 AM
segen77's Avatar
segen77
Default Question about fluid changes
I just got my 2916 recently still new on the lot, but it was built in Feb of 2016. I see a lot of posts about changing fluids out at certain time intervals. Oil once a year, Brakes every three years, etc. My question is, do I start the time clock from the moment the car was built, or the moment I bought it. (car had less than 10 miles when I bought it).
Old Jun 18, 2017 | 07:43 AM
Curahee's Avatar
Curahee
Default Follow owners' manual. Can't go wrong.
P.S. Please post pics of your 2916.
Old Jun 18, 2017 | 08:06 AM
Larry/car's Avatar
Larry/car
I would start the clock when you took delivery, want make any difference anyway. I would check what the DIC oil life is.
Old Jun 18, 2017 | 08:09 AM
Larry/car's Avatar
Larry/car
I would use the delivery date. Will not make any difference anyway. I would check the DIC oil life remaining information. Might reset to 0?
Old Jun 18, 2017 | 08:46 AM
rrsperry's Avatar
rrsperry
Rule of thumb.
Oil: at least yearly or as testing shows its needed
Brake fluid: at least every other year
Coolant: 5 years, or as testing shows it's needed
trans and diff: 3 years 30,000 miles.
Hoses and belts: 5 years
all from the date of build.
That's what I would do. You are free to do as you like.
Old Jun 18, 2017 | 10:26 AM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by rrsperry
Rule of thumb.
Might want to add changing differential fluid, or at least checking it, a little sooner since many come under filled from the factory. Mine was almost a quart low on a differential that only holds 2.5 qt.
Also, belts and hoses last a lot longer than they used to. When I sold my 2004 Z06 is still had the original belts and hoses, and they looked fine.
Corgidog1's Avatar
Corgidog1
I gotta think that fluids age the same whether it sits in your drive or the dealer's drive. If it were me I would start with Feb. 2016. I would think the oil life computer has no idea when the car was sold.
Old Jun 18, 2017 | 10:37 AM
Patman's Avatar
Patman
^^ I agree with the above. I once bought a brand new 1995 Trans Am in January of 1996 but the build date on the car was September 1994. So I treated it as such and changed the oil as soon as I got the car, especially since the car had 250 miles on it, so there were a lot of short trips/test drives that were done on it.
That being said, I don't think any of the fluids on your 2016 need to be changed any time soon, except for the oil (and even then it's probably fine but I would do it just to avoid a warranty problem if it arises). Don't even worry about the coolant, brake fluid, diff fluid, trans fluid, for a few years time.
Old Jun 18, 2017 | 05:59 PM
segen77's Avatar
segen77
Oil life monitor says that it has 97% left. I'm not sure if the dealer just reset the monitor, or actually did a change prior to pick up. It would seem that if Oil has a shelf life of five years, it could also sit in a car the same amount of time without having to be changed yearly. What am I missing?
Old Jun 18, 2017 | 06:13 PM
Patman's Avatar
Patman
Oil in a sealed bottle does have about a 5 year shelf life, but once you put it in an engine and start it, you introduce contamination into it, so that shelf life is now a lot shorter. I'd be most worried that a dealer would periodically start the engine, move the car a few feet, and then shut it down, and repeat this procedure many times over.
Old Jun 18, 2017 | 06:17 PM
TEXHAWK0's Avatar
TEXHAWK0
Starting the car and not driving it until it gets up to full temperature also allows moisture to accumulate in the crankcase and form acids and all sorts of bad stuff. The oil does not really wear out, it just gets contamination from combustibles and the additives get depleted.
That's why transmission and differential fluid last longer... They are not exposed to contamination from combustion and outside sources like dirt.
Old Jun 18, 2017 | 06:42 PM
segen77's Avatar
segen77
Ok. That makes sense.
Old Jun 19, 2017 | 08:56 AM
fredmills's Avatar
fredmills
Rule of thumb.
Why do you think you know more than GM engineers?
To Question about fluid changes
