Power steering failure
GM quality control is seriously failing.
GM doesn't even build the part Bosch does. GM has only testing on DV (Design Validation) and PV (Production Validation) parts, before PPAP (basically certifying the product for launch). That's done once per program or part (if it's carried over).
Hardware changes are retested in a limited fashion in terms of a shortened PV test to verify nothing went wrong.
SW is a whole other ball game. GM specifically is very hands off with supplier SW. They require the supplier to implement the interface so the module can communicate in the car as well as be diagnosed by GM technicians. However the core SW is typically owned by the supplier.
Suppliers have a rigorous testing procedure for the SW and share the results of such tests with GM. However GM has limited understanding of these results. Further this testing is done with a base calibration ONLY.
The calibration guys also do testing with each release but this is mostly in regards to stability and performance not in terms of diagnostic reaction (which is only tested with the base cal at the SW level).
Pretty often weird intermittent problems can be due to a bad connection.
I tried pushing on all the connectors and cables while car was running to see if it would go out, but didn't do anything.
I assume you have a lot of miles on it since they fixed it ?
Similar, but our cars reset once shut down and restarted
I seriously doubt Porsche trusts the suppliers to validate the PS that goes into the 911. Corvette obviously is not meticulous about quality control and therefore its PS units regularly fail.
Combined with the A8 failures, Corvette quality control is seriously lacking.
In this thread there are maybe 3 or 4 people with failures. The frequency at which your specific unit fails is irrelevant. The unit if it actually fails more than twice (and I don't mean reduces for temp) then the unit is bad.
There are some DTCs which are tested at ignition on (which is not the same as cycling your cars ignition, PS takes 1-3 minutes to shutdown after the car is off).
If I were to guess you have a latched fault for a "minor" hardware failure. These types of failures shouldn't be recoverable, but in some rare cases the unit actually fails, but on reboot thinks it's OK and turns on (because the hardware passes the power on test). Then you drive and the part of the hardware fails (again) and removes assist. The part in this instance needs to be replaced. And you should unplug it and drive manual until you do.
BTW, that's not normal, and is an "edge case" failure.
BTW, statistically speaking those people with issues are 10-20 times more likely to be vocal than those who are not. The amount of failures here is actually not indicative of the population. It's much higher. People come to forums mostly to complain. So your logic is backwards on that.
In regards to the latched faults I've been talking about sometimes its a combination of conditions and the nearly failed part to actually trip the failure. To explain that let me use an example.
Back in the day when I worked on a specific program, we had a failure related to ECU temp and current. So when the ECU was over a certain temp (below operating temp but above cold start temp), and then drew a specific current it would have a failure (this was due to a bad batch of parts). However the power on current draw test always passed because the cold start temp was preventing the part from failing. This obviously was due to a batch of bad parts, and not normal.
So I'd venture, if these units are actually bad, it's a combination edge failure and quality spill. So not typical, but they do happen (this is by far the biggest reason for recalls). We will know of these are isolated cases or not if a recall gets issued or not. If it's not a recall it could be something more benign like the parts got mis handled (or dropped) before being installed. Power Steering units hate being dropped, they usually break inside (look fine on the outside usually as well). Electronics are not very robust to 2-3 foot drops usually.
The car is an amazing car, beautifully designed and with great top performance, but their reliability is questionable compared to the new 6th. Gen Camaro that almost doesn't have any complaint.
1.- Some engine failures on the first year of the Stingray and Z06.
2.-Overheating at the track.
3.-Many issues reported by owners of the new A8 automatic transmission.
4.-7 speed manual transmission skipping shifts issues.
5.-And now on '17 that GM focused to take care of the overheating issues specially of the A8 automatic transmission, now they throw the ball again with the change of some components on the electronic steering wheel system, creating problems where there were none, this is completely stupid coming from GM that now created a very hazardous driving condition. I was looking for a brand new Stingray, and now I don't know if to only focus toward the '16 year, before GM's steering update or instead getting a '17 Camaro SS 1LE which probably would not have any bothering issues, I hate to have to take any car to the repair shop for unnecessary reasons, looks like GM has to take care of their quality department of not doing their job. I have a '14 Camaro ZL1, and never had to go to the shop besides the ordinary maintenance service. What changed at GM? These issues are a f....g disgrace, Corvettes are $55+ cars not a Yugo disposable car.
All cars have problems, and while you look at these items as "serious" versus "not serious" problems, statistics is statistics, parts will fail, manufacturing defects occur, and there is only so much quality control and engineering can do. Things are not perfect, and the mathematics behind them doesn't change. Quality defects can happen to any part and any manufacturer. So can design defects, look at the Takada airbag fiasco as a great example of a huge issue.
But back to my main point, just because you had no issues with your '14 Camaro and these people are having issues with their '17 Corvettes is not indicative of a process breakdown or a sudden lack of attention on GM's parts. Hundreds of people work with hundreds of suppliers to build these products. Sometimes **** happens, this is life. Usually a lesson is learned and it gets filtered back into the process thru continuous improvement, so if anything later model year cars are always better than earlier ones in terms of process, save for the quality spill (which as I'll say again are unavoidable).
Oh and BTW the new Camaro uses a Bosch gear which is a cousin (same SW and a lot of shared hardware) as the Corvette. The ATS, CTS, also use these electronics and much of the same hardware. Not that this should change anything, do you see ATS's and CTS's right now with issues?
I really think people's expectations are not in line with reality, and before anyone says other manufacturers don't have these issues, that is categorically false, they all do (yes even Toyota does), some just handle them better (and therefore the customers are happier and do not complain). If you want a simple car that does not break and you can fix it all yourself you have to go back to the 1970's.
