Corvette reliability
1. Z06 overheating/heat soak issues
2. Z06/GS wheel bending issue
3. A8 seems to have some problems- IDK, I'm a manual driver.
Electronics are one of those things- it's either going to go out early or not at all. If it doesn't fail in the first 3 years, I doubt you'll have touch screen problems.
My current 2017 GS M7 has had no mechanical or electronic issues at all, and only a few very minor cosmetic quirks that most people would not even see and are not worth fooling with, IMO. The SM at a local dealership told me it takes about two years to get the software right on a new model like the C7 was in 2014, so maybe this holds true on later MYs like the 2018-19 the OP is contemplating. Based on my experience with my 2017 I would agree that it is.
Bill
"CR can only publish the
Consumer Reports has clearly been biased in many instances in the past regarding automobiles (Re: Samurai, Ford Explorer) and I see no reason to believe they still don't color their "findings" according to their own biases.
Example of one of CR's "totally objective" statements: "One cheap way that automakers make an SUV less prone to rollover is to equip it with less-grippy tires".
They didn't say "could" -- they stated that it IS happening. No proof, just "feels".CR might be good for rating kitchen appliances and electric shavers, but their auto 'tests' have always been extremely suspect.
Many years ago I saw a cartoon in one of the car mags: C&D, R&T, or MT, I forget which. Two guys in the foreground are talking. A few bespectacled, white-coated "scientists" are in the background with clipboards as you see cars being pushed off a cliff. One guy says to the other, "Oh, that's just Consumer Reports testing cars again."
Bought new in November 2013
53,000 miles
new infotainment screen under warranty
new water pump under warranty
as reliable as any car I have owned
For my needs, what they provide is better than any other guideline for picking products based on survey results and their on-site testing. It isn't my only source of information but one that helps me along to make a rational choice. I tend to research products I plan to buy more than most people, to a fault I'm told, so I'll take the CR info and digest it along with any other sources I can find. For example, I just purchased a mini-computer for my home theater setup, and it took me two weeks of research to finally make the decision. I read everything I could lay my hands on, and had I not done it that way with all the variables involved (OS compatibility, RAM, storage, etc.) I could easily have ended up with something that didn't fit my needs.
