Quick Jack
Old Aug 2, 2017 | 05:57 PM
Hillbilly65's Avatar
Hillbilly65
Default Quick Jack
I'm thinking about getting a set of these.
Anyone used them?
https://www.quickjack.com/
Old Aug 2, 2017 | 06:00 PM
tcinla's Avatar
tcinla
A few have and have posted a few thread about it. My main concern is lateral stability. I don't want to be under the car and it move to the side and down... on me. I see there are cross bars so that should help maybe a jack stand or too just for good measure when the car is up on this unit.
Old Aug 2, 2017 | 06:06 PM
Hillbilly65
That is my concern also. It looks like it could be weak if some sort of side to side motion was applied.
Old Aug 2, 2017 | 06:10 PM
banph's Avatar
banph
2023 Corvette of the Year Winner - Unmodified
2022 C2 of the Year Winner -- Unmodified
I have one. I think they are great if you don't have the room for a 4 post lift. The car is very stable when lifted but I tend to be cautious so when in the full extended mode I put a set of Jack Stands near the from of them just in case something does happen.
Old Aug 2, 2017 | 06:26 PM
Flame Red's Avatar
Flame Red
Search is your friend. https://www.corvetteforum.com/forums...bl-5000-a.html
Old Aug 2, 2017 | 06:51 PM
chefcg1's Avatar
chefcg1
C7 of Year Finalist (performance mods) 2019
I love mine and use it on all my cars! Very stable!
Old Aug 2, 2017 | 06:59 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Reminded of what my Dad made me do when I worked on cars with him. Started when I was 10 or 12 and after we jacked up the car would sit the car frame on jack stands. Actually cement blocks as they were are jack stands!
He then made me hit the car hard with my shoulder! Recall once he said that was not hard enough, if it's going to fall better now when we are not under it! He had a friend killed when a car he was working on fell on him!
I will not use jack stands on both ends of the car. Even have a set of stands that clearly says in the warning label "Use Only on One End of a Car." Where possible my preference is jack stands on one end and stanchions under the wheels on the other.
Old Aug 2, 2017 | 07:16 PM
08G8V8's Avatar
08G8V8
Love my Quickjack. It is very stable. I have not read a single report of a failure.
Old Aug 2, 2017 | 08:04 PM
dprestidge's Avatar
dprestidge
Very stable, much larger footprint than jack stands. They are heavy steel. They work as advertised.
Old Aug 2, 2017 | 08:34 PM
jimmie jam's Avatar
jimmie jam
I have a 7000. What's not like about it...nothing for me.
Old Aug 2, 2017 | 08:39 PM
24/Eray's Avatar
24/Eray
quick video of my buddies with the GS in the air. Seems pretty sturdy to me?
Old Aug 6, 2017 | 12:01 PM
thespitz1's Avatar
thespitz1
3rd Gear
I just purchased the 5000 SLX this morning. Happy to report that I found a promo code "money" that reduced the price by $100. Hope this helps others who may be on the fence.
Old Aug 6, 2017 | 12:20 PM
TNSQUIRE's Avatar
TNSQUIRE
Mine is very stable
Old Aug 7, 2017 | 09:24 PM
dprestidge's Avatar
dprestidge
If you call them direct and tell them you saw their add for $100 off on TV they will give you the $100
Old Aug 31, 2017 | 02:30 PM
georgeobryan's Avatar
georgeobryan
2nd Gear
Default Carlisle
Today is the last day for the Carlisle discount. I just paid $1195 shipped without tax!
Old Aug 31, 2017 | 02:38 PM
TEXHAWK0's Avatar
TEXHAWK0
Check YouTube for a video by QuickJack where they intentionally overload it to prove how much weight it can carry before it fails, and push on it laterally to test stability.
It should be noted that one user had more trouble with the hydraulic couplers than with the steel lift itself.
Old Aug 31, 2017 | 02:42 PM
Kevin A Jones's Avatar
Kevin A Jones
I was a little skeptical prior to seeing a demonstration at Carlisle. Seem to work well and safely.
Of course a 4-post lift is much better and what, about a grand of so more?
To Quick Jack
Old Aug 31, 2017 | 03:42 PM
JakeC7GS's Avatar
JakeC7GS
St. Jude Donor '17
True, but a 4-post needs quite a bit more room for install, good concrete to bolt to, and isn't portable. The QuickJack is a nice solution for those of us with small garage spaces, might be moving, are renting, etc.
Old Aug 31, 2017 | 04:17 PM
JonMN's Avatar
JonMN
Another owner here. 5000SLX. Works great! I don't have room for a permanent lift, so this approach is ideal for me. On a humorous note, I bought it before installing my side-skirts--only to find it's rather useless for installing side skirts (in the way for drilling). But oil changes, wheel changes, etc it's going to be great. Thinking of a couple ramps to use with my ATV too.
Old Sep 4, 2017 | 11:25 AM
Apocolips's Avatar
Apocolips
I finally pulled the trigger on getting a Quick Jack. I got the 7000lb one so I could use it on both the Corvette and our other vehicle. I love it, very stable and high enough to scoot around under the car on my creeper.
