Orange Peel Paint
Old Aug 5, 2017 | 08:45 AM
DogTag-C7R's Avatar
DogTag-C7R
It's completely normal.......so is wheel click.......don't set your seat to it furthest back position......these things gm has conditioned us to accept as "normal" lol.....but we still wouldn't trade them
Old Aug 5, 2017 | 09:00 AM
John Micheal Henry's Avatar
John Micheal Henry
Originally Posted by madrob2020
As I just posted on Z forum, I'll repeat my guesses/observation. Orange peel occurs when the paint doesn't have enough time to "flow" & level out before it hardens. Much on the net speculates this has alot to do with U.S. EPA restricting the solid (paint) to solvent (liquid) ratio. Overseas not as much strict control (yet) on the solvent pollution problem. A new standard is gaining traction here using waterborne paint (many collision repair shops have switched). I wonder if the new paint dept for Vettes will be of the waterborne process.
madrob, GM has been using water based paint sence 1979..
Old Aug 5, 2017 | 10:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
its the application process not so much the paint
adding 10 coats of zaino will make it look even worse.
Old Aug 5, 2017 | 10:27 AM
golden2husky's Avatar
golden2husky
Originally Posted by Larry/car
I have a black 2016 Colorado and a 2017 Admiral Blue Stingray. The paint texture is the same on both vehicles. (Blame the EPA) Don't expect glass smooth paint from the new paint facility when the assembly line starts producing Corvettes again.
If the "EPA" was to blame, ALL cars would exhibit OP this bad. They don't. If I look at the Crystal red on a GM SUV and compare it to my Vette, the SUV's paint is much smoother.....hell, OP even varies Vette to Vette in the same color...
Old Aug 5, 2017 | 10:38 AM
B Chas's Avatar
B Chas
OK I now understand the popcorn thing. The orange peel thing bugs me, to the point that I was willing to pay for buffing or another way to have a better finish. Seems I'd just be asking for more trouble, without much chance for improvement.
It's nice to have access to so many experienced opinions here, thanks. The C-7 is so nice in so many ways, I'll accept the orange peel and won't risk making things worse trying to make the finish better.
Funny thing, my neighbor has a Mercedes AMG GT, in the matte finish. He paid lots and intentially choose matte paint that to me isn't as nice as my orange peel.
Still wish that buffing thing would have worked.
Old Aug 5, 2017 | 10:40 AM
madrob2020's Avatar
madrob2020
Not sure that is 100% correct. Could it depend on paint environment temp/humidity/maybe robot was programmed poorly? Plus doesn't GM use different plants all over U.S. so that's comparing apples to "ORANGES" The precise mix of paint (solid) to liquid (solvent) allowing consistent flow rate to even out paint highs/lows is paramount, which is what peel is.
Old Aug 5, 2017 | 10:44 AM
lagunabluez51's Avatar
lagunabluez51
Default Solution?
I noticed a little orange peel in my Laguna Blue Z51 when I took it home. I called Dave at Innovative Detailing in Tustin. He offers a solution to the paint issue. It is paint correction. I took it to him and he performed the service and my car looks like it should. Not cheap but awesome.
Old Aug 5, 2017 | 10:48 AM
madrob2020's Avatar
madrob2020
Ton's of folks have posted pics of their Vettes after they did a paint correction either themselves or professionally done. It is mind boggling to see some of the pics. You can see the crystal clear reflection of clouds/trees/even individual leaves. Go to your darkened garage & shine a small pro flashlite (40-60 lumens) from about 3' away at a 90 degree angle to your panels. The lite reflection will scatter & be blurry. Perfect paint presents a perfectly clear reflection when paint has been corrected properly. It does take a tremendous amount of time/patience to get it right & that is why shops who specialize in this can charge such a price.
Patman's Avatar
Patman
When I had my black C5 I literally spent dozens and dozens of hours going over the finish with my buffer trying to get the paint as perfect as can be and in the end I came to the realization that it's a never ending battle that you just can't win. When you see your car from 10-15 feet away you can't even see the flaws! So I've just learned to accept it. When I got my C6 it did have quite a few scratches and swirls but I have only spent maybe 10 hours in total with the buffer and have just left it at that. When I order my Torch Red 2018 next year there is a good chance it could be painted in the new shop, but if it isn't, I'm not going to lose any sleep over it. The new Torch Red cars I've seen on the lots so far look pretty good to me already, with an acceptable amount of orange peel.
Old Aug 5, 2017 | 11:14 AM
Jacob's Avatar
Jacob
Default A Solution is in the Works....
Went to a local high end detailing shop as I wanted to know what could be done. They did a test panel (the carbon flash metallic section by the rear license plate). I did a few photos:
Here is the panel before the repair:
Here is a side by side comparing the left side repaired with the right side unchanged:
The detailing shop does not use wet sanding to remove orange peel as they do not believe they have enough control over the amount of clear coat removed.
These were presented to dealer who contacted GM regional rep and quickly authorized paint correction to car and issued a PO to my detailing shop. Car is booked for repair mid August.
I am pleased with the quick response from my dealer. I will post a detailed update after the repair is done.
Jacob
Old Aug 5, 2017 | 11:42 AM
Foosh's Avatar
Foosh
Actually, the EU is much stricter than the US, and of course, that's where the majority of the world's "prestige brands" are built.
Virtually everyone, including body shops, have been using waterborne paints almost exclusively for many years now. That's about the only automotive paint available these days. Since all vehicles have been painted with waterborne solvents for many years, the only way the body shop is going to match it is with the same waterborne product.
Old Aug 5, 2017 | 11:59 AM
Frosty's Avatar
Frosty
yes
Old Aug 5, 2017 | 12:02 PM
  #33
DALE#3's Avatar
DALE#3
Jacob
Curious on how it is done without wetsanding.You have to remove the damage.Got to be polishing big time.Alot of Experience to get it right..
Staying Tuned
Old Aug 5, 2017 | 12:13 PM
  #34
Jacob's Avatar
Jacob
Staying Tuned
They used a small rotary pad with a denim like texture and an unnamed compound to take down the clear coat.
Old Aug 5, 2017 | 12:16 PM
  #35
madrob2020's Avatar
madrob2020
Jacob, just curious but why did they use that panel instead of inconspicuous spot of your blue paint to show difference? I would imagine the "real" car paint would show an even more dramatic improvement. Also, are they saying its the clear coat that has highs/lows that need to be leveled by polishing/not actual base coat (paint)?
Old Aug 5, 2017 | 01:00 PM
  #36
Jacob's Avatar
Jacob
The choice of panel was mine, for 2 reasons;
1. That is the worst section of orange peel on the car, and I figured if they could fix that, they could fix the body coloured panels with less serious peel.
2. Since this detailing shop was new to me and untested, I wanted to limit my exposure to an inconspicuous section in case they screwed up.
The paint correction is to the clear coat, not the base. The proprietor explained that with the rotary pad, the idea is to remove to the tops of the peel without removing any clear in the valleys. I do not anticipate they will remove all of the peel, but enough to render a decent looking outcome. They do measure the paint thickness prior to starting the correction process. My Ford RS (Germany) averaged about 200 microns, with about 50 microns of base coat and 150 microns of clear coat. It has peel but not excessive peel.
I first learned of this shop from a Porsche 996 owner who had good experience with them on 3 of his cars.
Old Aug 5, 2017 | 01:45 PM
  #37
scottaolsen's Avatar
scottaolsen
For what it's worth, I had a BMW and a C6 which were both used as daily drivers to work. Over 15k miles a year.
Same route, both cars. After 8 years the BMW looked like it had been sandblasted. After almost 10 years, the C6 paint looked perfect.
Got a C7 now, and no more work.
To Orange Peel Paint
Old Aug 5, 2017 | 02:27 PM
  #38
DALE#3's Avatar
DALE#3
I wonder how much one of them measuring gizmo's cost.That area you tested was real bad.They gotta use a lift to get the bottom right.
Old Aug 5, 2017 | 03:41 PM
  #39
joemessman's Avatar
joemessman
You get it in the right light and it really does show the peel at this angle.
Old Aug 5, 2017 | 04:25 PM
  #40
Jacob's Avatar
Jacob
Yup. Mine is similar to that in places. My wife's 2017 Ford Escape Titanium at one third of the price of the Z06, has a superior paint job.
