DSC shock controller - objective measurements?
Old Aug 10, 2017 | 03:29 PM
Foosh's Avatar
Foosh
It comes pre-programmed, but if you want "Tour Plush," call them and tell them that's what you want. I'd recommend it for rough roads, and you can always go to Sport to stiffen it up a bit. Sport mode on the DSC is far nicer than the OEM Sport.
I don't know what the warranty is, but I've never heard of an OEM controller failing, and I wouldn't expect the DSC to be any different. There aren't any moving parts, and it's a sealed circuit board. Contact dscsport.com and ask.
BTW, I did just find this on their website under FAQs addressing concerns about additional suspension wear.
DSC Sport does not add any stress to the factory dampers or other suspension components. In fact, the factory control method sends a constant current to the dampers, while DSC Sport alters the current and utilizes a series of on/off commands. Under normal usage, DSC Sport will ultimately send less current to the dampers allowing for better cooling during usage.
Old Aug 10, 2017 | 04:08 PM
Dif's Avatar
Dif
Originally Posted by pdiddy972
Upon ordering do you let them know which set you want enabled from the start? I saw mention that there was a set of settings for "plush" that makes Tour much more comfortable - I'd like that one while still having Sport and Track be as they should.
No Offense and understand you want to know all you can about the DSC Controller.
Please do not hesitate to ask questions on the Forum.
We're here to help
But I can't stress enough, that if you have not read this Long thread I posted a link to in post #4, you should read it
https://www.corvetteforum.com/forums...ervations.html
Pretty much All the info you need to know is in it, except maybe Warranty info.
DSC is very helpful and willing to answer questions with a phone call.
Case in point, a Forum member damaged his USB input connection on the Controller installing his.
DSC sent him another one.
And yes they will put the Tour Plush file in if you ask.
And even if they don't by mistake, DSC will help you, or you can put it in yourself as I did.
Either way you will not regret installing this Controller.
Foosh and I, and many others installed the DSC Controller over a year ago.
The Ride and more importantly, Handling with the DSC Controller is night and day compared to the GM Controller.
Old Aug 10, 2017 | 06:40 PM
pdiddy972's Avatar
pdiddy972
^^ Reading it now...
Old Aug 11, 2017 | 10:57 AM
RKCRLR's Avatar
RKCRLR
Playing Devil's Advocate regarding potential warranty issues, I could see GM trying to use the DSC controller as an excuse to deny a claim. Anything that increases performance could be viewed as putting more stress on suspension or drivetrain components than the car was designed for. Additionally, the controller software gives us the ability to screw things up. Someone could accidentally set the shocks to full stiff and hit a pothole and then make a claim for damaged components. I also noticed you could set the controller to send up to 2000 ma to the shocks. I don't know if the controller would actually do this, nor do I know if that would do any damage to the shocks. I realize these are unlikely scenarios but I prefer not to risk having a discussion about this with the dealer or GM. If I'm taking the car in for service and I think the dealer may be poking around in that area I'm going to put the OEM controller back in.
Old Aug 11, 2017 | 01:00 PM
Foosh's Avatar
Foosh
I can't see setting the shocks at full stiff being any different than running in OEM track mode. I don't believe the DSC controller will send 2000ma to the shocks, and I don't think there are any scenarios in which the DSC stiffens the shocks more than the OEM unit. The DSC actually makes Sport and Track modes more livable in the stiffest modes, meaning less suspension stress.
What the DSC does a better job of is softening and stiffening the shocks for better handling using a more sophisticated algorithm and more input data from systems already on-board. The OEM controller uses far fewer inputs so it tends more often to be stiffer than the DSC in the same situation.
In the FAQs on the DSC website, it is stated that the OEM controller is always on sending a constant current to the shocks, whereas the DSC has an on-off switch and alters the current such that it may actually be "easier" on the shocks than the OEM unit.
However, I see your point. You never know what a rogue dealer or area rep may do, and we've seen some ridiculous examples of that.
