Turn signals
I dunno.... the 3 flashes seem about perfect for me when changing lanes.
owc6 (09-26-2017)
Yep, works great for me, and the spring-loaded stalk giving you 3 flashes has pretty much become the industry standard. You're just signaling your intent, no need to complete the maneuver with signals flashing.
owc6 (09-26-2017)
On the Corvette, the detent on the stalk isn't as clearly defined as some other cars I've driven and I have on occasion triggered the permanent flash instead of the three flashes I intended. On the BMWs I've owned before, the detent was much more distinctive and easily distinguished between the two types of flashes.
It works just fine . . . you have to adapt to every different vehicle you drive. I never miss because I'm familiar w/ the feel. My Jeep is worse with a weaker detent. Yeah, I've had other cars w/ a more defined detent, but it's no big deal.
Like the OP, my 2017 doesn't work. I've had several C5/C6 and used this feature extensively on cross country trips. I know about the feel but I just finish another 3000 mile trip in the C7 and tried every combination of pressure and duration without success. I found that if you initiate a complete turn signal (passed the detent), then the lane change feature would operate correctly for maybe the next 1 or 2 times and then go back to not working at all. I will try the battery discount/reset tomorrow.
IOW, you see the indicators flash quickly, but nothing happens outside.
Have a good one,
Mike
