Turn signals
Old Aug 18, 2017 | 06:44 AM
Travelor's Avatar
Travelor
Default Turn signals
The Owner's manual for my 2017 GS states that the turn signals will flash for 3 cycles if the turn signal lever is "bumped" up or down.
Page 145
Turn and Lane-Change Signals
An arrow on the instrument cluster flashes in the direction of the turn or lane change. Move the lever all the way up or down to signal a turn. Raise or lower the lever until the arrow starts to flash to signal a lane change. Hold it there until the lane change is complete. If the lever is briefly pressed and released, the turn signal flashes three times. If more flashes are desired, continue to hold the lever.
My car does not seem to have read its owners manual as it does not do so. Anyone have this problem and is there a secret way to have this work?
Old Aug 18, 2017 | 07:02 AM
c54u's Avatar
c54u
I have a 2017 Stingray 1LT and have the above issue as well.
I have this "lane change feature" in my other gm cars and it works fine.....C7 no.
Old Aug 18, 2017 | 08:09 AM
Ramler's Avatar
Ramler
My 2017 Grand Sport works as advertised. Normally called a "lane change feature" and I use it all the time. Try bumping a little harder but not enough to actually turn on the signal.
Old Aug 18, 2017 | 08:21 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
All C7's have this feature.
Old Aug 18, 2017 | 08:23 AM
JaxC7's Avatar
JaxC7
Works great on my '17 2LT Stingray. The flash to pass activates before the lever goes over the detent that holds it in place for a full turn signal. I push and hold it just against that detent without going past.
Old Aug 18, 2017 | 08:26 AM
Walt White Coupe's Avatar
Walt White Coupe
The key word is briefly.
danh63's Avatar
danh63
I had on my Lexus also but with the C7 it does take a little more "bump" to get it to work
Old Aug 18, 2017 | 12:43 PM
Power Hawk's Avatar
Power Hawk
The lane change feature works great on my 2016 Base model. I use it a lot. Sounds like a trip to dealership is on order if yours does not work.
Old Aug 18, 2017 | 01:03 PM
vbdenny's Avatar
vbdenny
I have had this feature on a few cars, mainly Toyota/Lexus vehicles. The Corvette works about the same, brief bump and 3 flashes. Honda has the best system where the side mirror camera view shows up on the info screen, very good idea I wish the Corvette had.
For those of you in New York State it seems they didn't even install turn signals?
Old Aug 18, 2017 | 01:26 PM
c54u's Avatar
c54u
Well I decided to disconnect my negative battery terminal for a couple of minutes and connect it back up. Now the the lane change signal flashes three times when I use the feature.
Had my cruise control stop working in my C6 a few years ago, and did the battery trick back then and the cruise control started working and never had a problem after that with the cruise control.
Old Aug 18, 2017 | 06:16 PM
Grand Slam's Avatar
Grand Slam
Mastering the 'bump' is tricky. I still can not consistently do it each time.
Old Aug 18, 2017 | 07:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
But since three flashes is not really long enough unless you are lunging into the other lane, I just press it up against the detent and hold it there until my lane change is complete. Usually a lot more than 3 flashes.
Old Aug 20, 2017 | 05:56 PM
TEXHAWK0's Avatar
TEXHAWK0
I noticed my 2014 does that last week.. I bumped it to change lanes, and it kept flashing after I let go..
Old Aug 20, 2017 | 09:01 PM
carney1's Avatar
carney1
wish my C7 had signals like my C5, in that if you bumped and held you got a very rapid turn signal for changing lanes, really could be noticed
Old Aug 20, 2017 | 09:06 PM
JGarland's Avatar
JGarland
What is a turn signal?
Old Aug 21, 2017 | 10:57 AM
RedC7AZ's Avatar
RedC7AZ
The stalk that extends from the steering wheel that ignorant, rude drivers neglect to use.
Old Aug 21, 2017 | 11:01 AM
JGarland's Avatar
JGarland
Never needed to use one since nobody is ever that close behind.
To Turn signals
Old Aug 22, 2017 | 01:21 AM
Grand Slam's Avatar
Grand Slam
My C5 worked like all the other cars I've driven. Hold the turn signal without latching it and it flashed at the same rate as it would if latched.
Old Aug 22, 2017 | 07:23 AM
user051728's Avatar
user051728
The stalk has a "detent" if you pass the detent it stays "on" if you just touch the stalk downward and let go before hitting the detent you get the 3 flash signal.
99% of all cars work this way now.
Old Aug 24, 2017 | 09:59 AM
carney1's Avatar
carney1
Default signals
I wonder if my had a mod on it then....like I said, I really liked how they worked flashing rapidly
