Bluetooth
Old Aug 19, 2017 | 11:52 AM
Don C1's Avatar
Don C1
Default Bluetooth
Has anyone had a problem getting their iphone and car to connect via Bluetooth. Had the car over a year never an issue. Took the car out last night and discovered no connection. Have tried reconnecting several time through "settings>Bluetooth>pair device and seems my cell can find My Chevrolet link but won't connect. Any ideas ?
Old Aug 19, 2017 | 12:51 PM
buckeye4's Avatar
buckeye4
You might try this as I had a problem with my bluetooth connection. My dealership Corvette Tech cleared the problem. GM is working on the permanent software fix but can be temporary repaired by Selecting Settings from the Radio Home Screen- Return to Factory Settings- Clear All Private Data. You will need to pair previous paired devices and update phone and audio settings. Problem is across all GM 2016 and 2017 models. My tech gave me the GM document #PIC6216C which covers the problem. I have a 2017 and Samsung S8 and have had to reset 3 times in the last 6 months.
Old Aug 19, 2017 | 01:24 PM
blkvet6's Avatar
blkvet6
Default Copy of PIC6216C - Anyone have this Bulletin?
Hmmm, I don't doubt you, but I just went to the Corvette Action Center, and PIC6216C is not there. However, I note that there is another Bulletin that includes bluetooth problems. Luckily, I am not experiencing this problem, but just curious.
Old Aug 19, 2017 | 02:12 PM
buckeye4's Avatar
buckeye4
Originally Posted by blkvet6
hmmm, i don't doubt you, but i just went to the corvette action center, and pic6216c is not there. However, i note that there is another bulletin that includes bluetooth problems. Luckily, i am not experiencing this problem, but just curious.
Voice Command Fix page 1.pdf
Voice Command Fix page 2.pdf
Old Aug 19, 2017 | 08:03 PM
Don C1's Avatar
Don C1
Thanks for the info tried it and no luck. Get message about setting pin #. Will connect by car play (usb) but no Bluetooth.
To Bluetooth
