Adding Nav
Old Aug 27, 2017 | 08:10 AM
Steve2150's Avatar
Steve2150
Default Adding Nav
Have a 2015 and want to add Nav again. I say again because I ordered the HMI from a vendor and while it worked perfectly it clashed with my onstar system giving me the red light and error not receiving onstar, whenever I called onstar they could not determine my location. Called the vendor and they were not able to fix it so I returned the HMI. Has anyone installed the Nav hmi and been able to use onstar also. Different vendors? or is the onstar module mated to the hmi.
Old Aug 27, 2017 | 08:35 AM
dmaxx3500's Avatar
dmaxx3500
and you use onstar for what,ive added nav to 2 c7 cars and a bunch of gm trucks,75% had onstar light afterwards,and 1/2 the light turned green after a few weeks
nobody knew why,and nobody really cared,because everything worked,[nav,gps,bluetooth]
Old Aug 27, 2017 | 09:19 AM
Steve2150's Avatar
Steve2150
Onstat was interferring with the GPS
Old Aug 28, 2017 | 12:19 AM
Pickle1234's Avatar
Pickle1234
I was told you could add nav if it didn't come with Nav from the factory. Was told that it is hard wired to the radio /info system. Is that true
To Adding Nav
