GM will pay for one free alignment on all new cars. I had my local Chevy dealer check the alignment on my 2015 at 4K miles, and it was way off. They adjusted it for free. I had them recheck it at 10K miles and it was still good. I now have 25K miles on it and front tires are good, and look like they have another 10K left on them!
Duck Hunter,
Which car do you have?
Base Stingray?
Z51?
Z06?
Did they make any adjustments at 10k miles?
And did they charge you again for another alignment at 10k miles?
We've had three previous new Corvettes, and every one of them had at least one parameter that was outside even the very wide factory specs.
Taking the new 2017 in soon, "uh, it pulls to one side".
Took the new car in at about 2k miles, winked at the service writer and said "The car wanders at high speed. Here's the alignment numbers I'd like. If it is within spec now, set it to my numbers and charge me. If it was out of spec, set it to my numbers and charge to warranty. Deal?" He smiled and agreed.
No surprise, both the fronts had excessive toe-out that really eats tires, just like all three of our previous new Corvettes; and one of the fronts had excessive caster that was much different from the other side.
In the past, there was a minimum mileage (500 miles?) before GM would do a warranty alignment, and a maximum mileage (7,000 miles?). I'd recommend getting it checked soon after 1k miles, that should have everything settled but not waste too much of your tire tread before correcting any problems.
Are these specs only for the GS & Z06 that have much wider tires than the Base model Stingray and the Z51 ??
Are the specs different for a Base model Stingray??
Originally Posted by rikhek
Come on man, we're talking about CASTER, not camber. ANYBODY can set camber, that's the whole point!!! Read the thread, the important setting is REAR CASTER!!!
They DID NOT set this VERY important setting and only charge $155!!!
Does anone know if the Base model Stingray (non-Z51/GS/Z06) has this same issue of REAR CASTER adjustability??
Look at post #8. For a Grand Sport it shows and rear camber to be -1.1 with and acceptable tolerance of +- 0.6. That allows a -0.5 degrees on both rear tires if you wanted to sacrifice some max cornering speed at the limit for better tire wear. The fronts can be as little as 0 Left, -0.3 Right.
FWIW, my rear tires came from the factory with one rear at -1.7 (note, within the GM spec on the max camber side.) Had my camber reduced from centerline for better tire wear. Out of town so don't have specific values.
DSC Sport recommends the same specs for all C7 models. Factory alignments are crude at best and all over the map.
And yes, the rear caster should be set properly on base models too. They are just as likely to have positive caster on one side and negative on the other. That is not good.
Just got off the phone with Campbell Chevrolet in Bowling Green KY, and they do not have the tools to adjust caster. They asked me to call Leachman GMC across the street from them, but they too do not have the tools to do the adjustment. I'm picking up the car at the Museum around the last week of January of the first week of February and driving it from KY to NC. Anyone know of a dealer anywhere between KY and NC that might have the tools to do the proper alignment? I'm going to stop somewhere along the way and swap out the stock brake pads, so would love to have the alignment done at the same time. Anyone have any info on a dealer that might fit the bill here? Thanks in advance if anyone knows anything!
My experience has been that it takes a couple of hundred miles, or more, for everything in the suspension to settle out properly.
You might consider finding a dealer close enough to your home that you can drive the car 500-1000 miles, then get the whole alignment setup checked/adjusted and be able to use them again when/if needed.
I don't know about rear caster, but the other settings in Corvette alignments are usually not a "set it once and forget it" thing, they should be checked periodically. I didn't try to keep records, but it seemed like my alignments were usually still good after 5k miles but took some adjustment after 10k-20k miles.
Thanks! I'll just have it checked once I get home then, that should be around 700 miles or thereabouts. I appreciate your reply! Although I AM going to have the brake pads changed out at the Chevy Dealer in Bowling Green. Don't want tons of brake-dust on the wheels while driving it home. Thanks again!
I have been measuring the tire (inner & outer) tread on all four tires since the beginning. With 9500 miles the tread is wearing evenly across all four tires which tells me I don't need an alignment.
The one thing I have discovered it's hard to find a dealership or tire store that has the tools to adjust caster along with experience adjusting the C7.
Good idea if you're going to pay to have the pads changed to do it where there is no need to clean the rotors. Assuming you'll bring the pads with you.
I had the ceramic pads ready and installed with 30 miles on the car the day after I drove it home from the dealer!
I had 400 miles on the car when I brought it to a local dealer. Be sure they don't just check them as all my camber's were within the broad GM spec and one rear was at -1.7 degrees, the max allowed. They *** read in the green. I had them reduce the camber on the lower side of the spec, which for that same wheel could have been -0.5 degrees! I did not go that far! I did have one toe out that was centerline by the GM Tech. All paid for by GM.
I have already ordered a set of the Carbotech pads, and as long as TSA will let me carry them in my carry-on luggage, then I'm taking them with me to Bowling Green. I've already spoken to Campbell Chevrolet in BG and they said they could knock it out in a hour or so, for $108 if I supplied the pads. So I think we're golden.
