Hot Trans warning
Old Sep 17, 2017 | 05:32 PM
CorvetteKing_Tony's Avatar
CorvetteKing_Tony
Default Hot Trans warning
i have the base stingray and got this warning on dash today. The A8 was so hot I thought car was going to stop. When I slowed down the trans seem to keep slipping. My car also has a loud noise under car like 1000 pennies moving around in car. Seems to be right behind trans. My car has 1600 miles.
Old Sep 17, 2017 | 05:40 PM
curve65's Avatar
curve65
Bummer big time, sounds like it needs to go to the dealer to me, maybe on a flatbed. imho
FastC7GS's Avatar
FastC7GS
Get it in to the Dealer, If you need further assistance PM me. A defective A8 is surly no surprise.
Old Sep 17, 2017 | 08:01 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Were you driving "spiritedly"? Paddle shifting?
Old Sep 17, 2017 | 08:06 PM
davepl's Avatar
davepl
Yep, like a notchy M7, pretty common in the Stingray and GS.
I wonder if the OP checked the actual trans temp? I'd believe the DIC that it's too hot, just curious what the temp was.
Old Sep 18, 2017 | 03:17 AM
djnice's Avatar
djnice
What does he mean, "seem to keep slipping"? Where exactly are the 1000 pennies? If they are behind the trans then they are in the diff, but he says "moving around in car". I don't know.
Old Sep 18, 2017 | 07:20 AM
bigblock427's Avatar
bigblock427
Old Sep 18, 2017 | 10:12 AM
Frosty's Avatar
Frosty
Was there ever a class action lawsuit on the A8 attempted? My god, all these reported problems on low mileage cars is ridiculous
Old Sep 18, 2017 | 01:45 PM
djnice's Avatar
djnice
I don't see any indication of trans temperature. Maybe its just a faulty connection giving a bad signal?
Old Sep 18, 2017 | 02:29 PM
Mobil 1's Avatar
Mobil 1
I see his engine oil temp and pressure gauges look normal. What are you seeing besides the warning message>
Old Sep 18, 2017 | 03:33 PM
NSC5's Avatar
NSC5
What sort of transmission cooler do you get with the A8 in a regular Stingray currently? The cooler was very small when the C7 first came out unless you got the Z51 package; now the Z51 and above A8 get the front horizontal cooler in addition to the smaller one mounted in the rear quarter panel. Look through the grill and see if you can see a large cooler laying horizontally (flat) in front of the main cooling stack and if so you also have the second larger transmission cooler.
If you were doing spirited driving in hot weather you may have exceeded the capabilities of the rear cooler but it is quite possible its fan isn't working or it has picked up debris.
Old Sep 18, 2017 | 06:45 PM
CorvetteKing_Tony
the temps were okay and I had only drove car for 30 minutes on regular streets. I have sent pictures to GM. It would not go faster than 50.
Old Sep 18, 2017 | 06:47 PM
CorvetteKing_Tony
When I would try to stop the car wanted to keep going like the trans was just changing gears as I slowed done.
Old Sep 18, 2017 | 06:48 PM
CorvetteKing_Tony
Only drove car for 30 minutes on main streets. I don't drive fast at all. I only have 1600 miles on car.
Old Sep 18, 2017 | 06:51 PM
CorvetteKing_Tony
I have contacted GM's Excutive Office with my complaints. This crap is awful. Then washed car today to only find one of my air ducts in rear had been pop riveted into place to hold it. That's why I'm getting this awful sound.
To Hot Trans warning
