Have you looked at the how-to thread on installing it ? It's not that hard, will take a couple of hours if you take your time but it's straightforward and you'll save a bunch of $$
Two people make this a much easier install. The hardest part is fishing the wires under the dash - well that and getting to the plug to unplug the controller.
If you have tools, buy me a round trip air, cook steaks, transport from and to airport, good supply of beer, I'm available for remote work! (After I get rid of my sling for bicep and rotator cuff repair)
If you have any mechanical ability, you can do it in your garage. Drag in a friend as it might help in the work or just to BS with while you do it.
To the OP here do it yourself it is simple to do. If I can do it in about one hour anyone can do it. computer in the pass/side floor, unplug then plug this into it, run wire thur dash, then run wire camera thur pass/side door& fender under hood out to the grill. This is about it... No holes to drill are do nothing hard at all worse thing is getting the wire run from pass/ side to the drivers side.. Robert
I totally agree, not a bad job with 2 people, especially if one can be somewhat of a contortionist.
