Paddle shifter
Old Sep 21, 2017 | 03:42 PM
stevef4d's Avatar
stevef4d
2nd Gear
Default Paddle shifter
Why did the paddleshifters switch from c6 to c7 operations???.easier with the c6 than the new c7...
Old Sep 21, 2017 | 03:57 PM
Glenmcp's Avatar
Glenmcp
I believe down on left and up on the right is pretty much the auto industry standard. I guess GM just decided to go along.
Old Sep 21, 2017 | 04:07 PM
stevef4d's Avatar
stevef4d
2nd Gear
Thank you..i was afraid of that....c6 was more "user friendly"....never had to make sure one was using the right paddleshifter...oh well!!
Old Sep 21, 2017 | 05:59 PM
redman76's Avatar
redman76
St. Jude Donor '09
That is what we were taught at Spring Mountain. Left- and Right+ was standard on all/most track cars, regardless of manufacturer.
Old Sep 21, 2017 | 06:30 PM
dvilin's Avatar
dvilin
Sounds simple enough and makes sense to me.
Old Sep 21, 2017 | 06:58 PM
chefcg1's Avatar
chefcg1
C7 of Year Finalist (performance mods) 2019
I much prefer the push to down shift and pull to up shift of my bmw.
Old Sep 21, 2017 | 08:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I much preferred our C6 setup, especially if using the paddles in an autocross or residential streets where you may need to switch hands on the wheel for tight turns.
You could always get the desired result with either paddle.
Old Sep 21, 2017 | 09:22 PM
Dif's Avatar
Dif
^ Being an industry standard or because it's that way on most cars doesn't make it better
The C6 setup is much more user friendly in any situation, especially on the street
Old Sep 22, 2017 | 12:41 AM
Kruegmeister's Avatar
Kruegmeister
I think you're just used to it.
I think if it was backwards (the way the C6 apparently is) would be less user friendly.
Actually for me the best Paddle Shifters are on my F430, they do not rotate with the wheel and + is on the Right there as well.
Old Sep 22, 2017 | 01:21 AM
ElGreco53's Avatar
ElGreco53
My last 2 cars, Jag XKR and MB AMG, had paddles left/-, right/+.
Luckily the transition to the C7 was seamless since GM changed things.
Old Sep 22, 2017 | 04:47 AM
Dif's Avatar
Dif
Yes sometimes we get used to things and don't like change.
And agree with something like F430 paddles, but they're also much larger and easier to grab if the wheel is turned.
With the C6 you can push to upshift, or pull to downshift with the Left or Right paddle even if the wheel is turned 180.
C7 is strictly left - right+, but if the wheel is turned 180, now it's opposite, left+ right -
Old Sep 22, 2017 | 12:34 PM
ElGreco53's Avatar
ElGreco53
with a little mental anticipation, I learned to paddle shift with the wheel 180º, ie shifting down with my right hand. It just takes some "mindfulness"...going slow helps too!
To Paddle shifter
