Vararam C7 True Cold Air!!!
#122
Supporting Vendor
Just Email us your info and what tuning software your or they are using etc..
vararamindustries@gmail.com
VR tech
#124
Supporting Vendor
There is adjustment built into the unit.
Super easy to correct.
Loosen the two air-box bolts on the fender as well as the hose clamp on the intake tube that connects to the throttle body.
Pull the air-box back towards the firewall and retighten the air box bolts, then tighten the hose clamp on the TB. This will give you the clearance required for proper fit.
If you have any questions just give me a call 832-701-7700 and I will walk you through it.
VR tech
VR tech
#125
Damn I _just_ finished putting it back to stock. I honestly think it was a height issue anyways. Either that or the hood strut bumping up against the latch of the airbox. The sticky foam broke too. So, no going back. I mean, your basically telling me to loosen and pull?
#127
Supporting Vendor
That will provide the clearance from the hood strut mount.
Happy to send you another piece of strip foam if needed.
VR Tech
#129
Supporting Vendor
iw172 (02-10-2019)
#131
This gap, it's normal? It renders the latch nearly irrelevant.
Thanks Taz. I think I remember you from when I had my Cobra. You were a ball buster then too. Time goes slow when your hood is all effed up. Gain a few rwhp (20 unlikely) along with a misaligned hood? Cost benefit just didn't make sense. I'm obviously willing to revisit.
#132
Dude, you definitely have it mounted way too far towards the front (nose) end of the car, and its probably hitting the hood strut. Just loosen and slide it back towards the cockpit...
Use my pic as reference.. The height of the airbox should be flush with the top of the foam piece as shown.
#133
Dose it come with/without filter. I just bought an Attack Blue, not installed yet.
#134
Supporting Vendor
Had the Same issue....But
As VR said just said it was mounted to far forward. Loosened it up and pushed it back and it worked fine.... got to take it out and ran it for about 45 miles and it made a difference....and then put it away for the winter...
#136
Received 1,073 Likes
2015 C7 of the Year Finalist
When do you expect to release the C7 Z06 system?
I am currently using a stock CAI with a Tony Mamo throttle body on my 2015 A8 Z06, will this affect your CAI?
thanks
George
thanks
George
#137
Supporting Vendor
No , it will not affect it , the system was designed to handle stock to 1000+ horsepower cars. I am sure you will have to Re-tune it, since you do not have a stock car.
We are trying to get as many Z-06's in our facility as possible to test final development parts now. We have to verify ECM variations from year to year, auto vs stick etc.. . Once we green light everything it takes a couple of weeks to ramp up production. Holidays just always slow things down.
We are on it !!
VR tech
george vee (01-04-2018)
#138
Supporting Vendor
Supporting Vendor
Been a cold and long winter already!!!
Don't know about you but we are ready for spring time like now!!!
This winter has seemed longer and colder than usual! Want to get outside
and wash the vehicles and feel a little sun on the face! Hang in there - it won't be long!!! We are continuing to develop new units while we are stuck in the shop! Get your tax returns filed and have that extra money for fun stuff!
