Corvette Tech?
Need to take my 2018 A8, NPP Stingray to dealer to have the warble sound looked at. When I make an appointment do I need to request the corvette tech? Anyone know any dealer they trust/recommend in central NJ?
Thanks!
Thanks!
You are not alone my friend. There is some good information in this thread, and how to go about getting the correct repair. It's quite a long thread, but the info on contacting GM's TAC center will help you greatly. Good luck.
It's quite sad that GM knows about this problem, and have let it go on for so long.
https://www.corvetteforum.com/forums...asionally.html
Thanks! wondering if I should start with an email to GM and then have them call or contact the dealer near me? This way the dealer knows I have already contacted GM and they are trying to point me in the right direction?
How can I contact GM's TAC center?
Thanks!!
Thanks!!
FYI: I haven't taken mine in yet as the "warble" has dropped in decibels to low to hear over the regular noise. From what has been discussed mine is at the wear point of just breaking, and then I'll be hauling it to the dealer. Shouldn't be any questions after that.
St. Jude Donor '15
"In honor of jpee"
I kept a list from various CF members and it includes: Paramus Chev (Giovanni to do the work), Ayers, and Gearhart. Pine Belt Chev and Lester Glenn (Tommy to do the work), Freehold Chev (Kevin to do the work). All from 2013-14. Hope this helps you.
I've run across one or two favorable comments on Malouf in North brunswick. Never used them myself
I'm in Trenton and chose to go 40 miles across the river to Bryner Chevy in Jenkintown Pa.
The Corvette service manager is Chris Stacy. Corvette tech is Steve Spence
I've been there 4 or 5 times. Twice for track alignments(including rear caster) once to drain diff fluid after first track event ,once for seatbelt TSB, once for warped brake rotors (replaced under warranty) and to replace failed AFM actuator
Treated very well every time and all work was always done to my complete satisfaction .
contact marry barr at gm, im taking mine in wednesday. a g.m. tech is going to be their to fix the problem.......will see
The place that put in a new trans said the wabble sound was normal. I belong to a corvette club in florida and drove 2016 vetts the people own, no wabble at 1500, im not going to buy...……….the noise in normal. But if i trade it in, they are going to say their is a problem. What a joke the car was at chrystal chevy in crystal river florida
i want a document saying that the wabble noise is normal with my car. Then when it takes a crap later on, i have paper work. But if i trade it in, and they drive it, and they say something is wrong with the rear end then when. Show them the paper work signed by gm. I getting fed up with thir ****
St. Jude Donor '15
"In honor of jpee"
Edit: Just saw john's post #11 above. So, Gio is getting around but now back at Paramus.
Freehold Chevrolet closed a few years ago. Kevin , one of the best is now working at Freehold GMC/Buick. He works on vettes at that location but the dealership might not want to take on new corvette customers. Alternative is Quality Chevrolet in Old Bridge they also have a couple of vette techs
I authored the original Post on the WARBLE and the key is getting a good dealer service manager to hear and do his home work in calling eng or tech support for authorization to replace diff with a new improved one not old stock. Suggest you find best dearer of your choice and before you take car in test out surrounding roads and find a stretch where the car displays the WARBLE best, slight incline while light acceleration. Take the SM or tech a ride on this same stretch of road so you get the WARBLE result. Warble is not normal and all the dealerships say we never heard of this problem, I don't believe them. Good luck and document your problem in the original post if you would so it is all in one place instead of multiple post. Let us know how it goes.
St. Jude Donor '15
"In honor of jpee"
I'd be surprised altho dealers do odd things. Still, it's a paying customer coming thru the door for a tech/mechanic who knows how to do the work on another GM brand/make. Maybe someone could ask him/them???
