Leather on dash delaminating
#161
Glad I have a 2LT. Seen a lot of 3LTs with the dash coming apart. Went to look at a 2014 vert and half the dash was loose. It was at a Ford dealer and they had no intention of doing anything about it (understandable... took on trade, need to move metal).
#162
It seems that it should be possible to reglue that part of the dash, so I'll ask the dealer. I'm wondering what type of glue they use. 3M super 77 is good for gluing all sort of stuff (carpet, plastic, metal, ....) and in my case for a wing slot in an EPP foam radio control glider (which is why I bought that glue).
#163
Add me to the list. This is a 2014 3LT. I just bought the car, I didn't notice this until I got it home and under artificial light. It is much less obvious in sunlight. I will see what the dealer has to say first. I did buy an extended BTB warranty. Actually, if it got no worse, I could live with this. But thats probably wishful thinking.
#164
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Typically extended warranty's are not covering the Dash. But unlike those that are pulling away and leaving a gap, yours looks fixable. Steam and perhaps glue injected with a needle from the seam?? Not sure how GM's coined name, “Mulan" synthetic leather reacts to steam? It's made from ~40% ground up leather scarps and other "stuff."
It appears those of us with 1 and 2 LT interiors must have vinyl dash covers as few reported issues.
I sure can’t tell the difference in my 2LT Grand Sport Vinyl dash cover and my prior 3LT 2014 “Mulan” synthetic leather. Both materials use “leather look” embossing rolls in manufacture.
#165
Location: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Received 1,142 Likes
#166
C7 of Year Finalist (performance mods) 2019
#167
My car just turned over 10k miles and I just noticed that mine is doing this also. The area around the central defrost area extending about 2 inches down the dash is loose. The defrost duct there is also loose. 2014 3LT I don't know of a good GM dealer in the central Texas area but I have an extended warranty that I guess I can check with.
#169
#170
Hmm, had not heard the "Upper Dash Pad" called that!
Some of us installed the seat colored one on our 2LT's before GM added that to a 2LT. In fact IMO, it's a better solution as the colored panel above the glove compartment GM also added makes in look like a "Patch Work Quilt" IMO!
PS: The OP's Dash needs more than a new "Upper Dash Pad!"
2017 Red Interiors
My 2LT After Adding Seat Colored "Upper Dash Pad"
2017 Red Interiors
#171
I went to Chevy's site and built a 2019 Vette with trim 3LT. Nowhere in the description of the 3LT trim does it say that the dash is leather, or any different from trims 1 & 2. It says:
- Custom leather-wrapped interior (information panel, door panels, center console cover and seats).
#172
Had a 3LT 2014 Z51. I looked for 3 years and all you will find from GM is the 3LT has Nappa (or Napa both sp's ok) seating surface. That is real leather tanned a certain way. In a post a fellow who worked for GM described how they tested material for bolsters and real leather we inferior (but he never said what was better but said the bolsters are NOT real leather.)
GM literature says the other surfaces are "soft touch" materials. That includes Mulan "leather," which is their name for synthetic "leather." It consists of ~40% ground up leather scrapes and it's made from other synthetic materials similar to vinyl. The same as Chryslers' old Corinthian "leather" that Ricardo Montalban admitted was a name coined by Chryslers ad agency.
So when GM says leather it's assumed (other than the 3LT seating surface) they are referring to Mulan synthetic "leather." The reason for assuming the 3LT dash is made from Mulan and the 1LT and 2LT are made from vinyl is there are very few issues posted with those 1 and 2LT lower levels. Many posts on 3LT dash issues.
#175
The dealer did repalce the bat wing under warranty. The HUD area seems like it may be next. Do you know if that is a seperate piece from the rest of the dash? It must not be part of the bat wing, because it was not replaced with the bat wing.
chefcg1 (07-22-2019)
#176
[QUOTE=gandkand3;1598378332]
The entire dash had to be replaced, not just the HUD area?
Can we get some more pics from folks who are have problems?[/QUOTE
2018 Z06, Had it about three months and saw this. I brought it to the service department yesterday and within 30 seconds of seeing it the service adviser was ordering a new dash. I asked if this was common and she said it was the third one she had seen in the last two months. I was in there a total of five minutes, no hassle getting them to warranty it. When I had spoken to my sales rep before I went up there he had said there was a TSB for it, but he wasn't there to ask. When I asked the adviser about the TSB she wasn't aware of one so not sure if my sales guy was wrong that there was a TSB. I'll try and catch up with him when I get back over there. Please excuse the dust, been sitting in the garage for a few weeks. Dealership was Rick Hendricks in Norfolk.
#177
A couple of things.....
1. I found I had an issue ("bubble") with my upper dash near HUD.... thankfully while it was still under B to B warranty.... (pictures below.... hard to see location in second one due to glare!
2. Dealer agreed it should be replaced under warranty..... entire dash removal!!
3, Upper dash part (at that time) was on national backorder.... indicating to me more than one owner was having the issue!!??
4. When said parts came in, it did take the dealer several days to do the job but thankfully they fixed it right and did not insert problems
5. Tried to determine if replacement parts were redesigned to address this problem.... did NOT have conclusive information to answer that question
6. Will/could it happen with the new dash..... this was over a year ago and so far so good!!
Moral to me..... GM stood behind the issue for me and MAYBE did some redesign or improved their mfg. process.... time will tell.
I side with those that wonder how acceptable a dash cover is on our beautiful C7s.... but that is MHO....LK
#178
I have a 2016 3LZ always garaged and parked under car port at work 11385 miles. Discovered today that the passenger side is delaminating in the main segment about half the area. Out of warranty. I bought it new from the dealership. This is not hearsay or conjecture btw.
#179
Sorry to hear about the issue. If delaminating perhaps it can be repaired but many on this Thread had 3LT dash "leather" shrink around the vent opening. Currently have a 2LT Grand Sport and a 3LT C8 on order. Reminded of a recent Thread where folks questioned if Mulan "leather" was real tanned cow hide. Thought that had been defined years ago when I had a 3LT 2014 Kalahari dash. It remains a concern for the C8 on order with a 3LT interior. .This is my understanding reinforced by this and similar Threads re 3LT dash issues.
All you can find GM officially saying re C7 interior materials and other "proof" is:
If what many posts on this Thread indicate is an issue, i.e. shrinkage of the 3LT dash material from the vent opening the solution is to have the dash material replaced. Expensive and getting it done properly is usually a specialty skill Dealer's will send out to have done. Would be cheaper if you could find their source.
I proposed another possibility, using fender welting to fill the gap. It comes in various colors and some suppliers offer to dye to a color. May not be the ideal solution BUT it's far cheaper than replacing the dash, which is NOT a foolproof solution that it will look perfect when finished.
- The 3LT seating surface is Nappa (or Napa) Leather. That is real animal hide using what was a specific tanning process but today it varies.
- GM states, all other interior "soft touch" materials are Mulan "leather" of vinyl. They nor will you find "officially" what Mulan "leather" is- IT IS NOT A tanning process.
- It has been validated (to my satisfaction for 5+ years) that Mulan is GM's coined name for bonded leather with up to 40% ground leather scraps man made similar to vinyl. Best proof, IMO is a person who interviewed folks at Bowling Green and a manager made that statement. But from GM's lack of saying specifically what other than the 3LT seating surface is "real tanned leather," the other "leather looking" materials are not!
- A GM engineer had posted they tested materials for bolsters (not a Corvette) and found real leather was not the best choice. IMO this further validates the the 3LT seating surface and only the 3LT seating surface is real tanned leather- and the seat bolsters are one of the other "soft touch" materials!
- The dash degradation issues appear to be isolated to 3LTs as there are no reports of issues with 1LT or 2LT dashs (or if there are only so few I never saw the reference.) BY DEDUCTION: the 3LT would appear to be made from bonded leather, GM coined as Mulan. Similar to Corinthian leather Chrysler's coined name. (In fact, years after he was Chryslers' spokesman for Corinthian "leather" Ricardo Montalban in an interview said Chryslers ad agency made up the name!) The 1LT and 2LT dash would appear to be made from a different material than GM's Mulan Leather i.e., vinyl. Both bonded leather and vinyl are processed through embossing rolls and have a leather texture. Both come on large rolls, much easier and cheaper to made into dash, door panel etc parts than isolating undamage sections real leather tanned hides!
#180
I am going to see what my dealership will offer to fix. Then. I am going to see what an upholstery shop will suggest. It is purely a failure of the glue. To say this car has been babied is an understatement. I did find a YouTube of an out of warranty replacement/repair for 956.00. Concerned as others have mentioned even if fixed it likely will happen again since I like to keep my cars for quite a while. This should not happen to a 4 year old car IMO. Especially that rarely sees direct sun and especially since it is a convertible.
JerryU (10-27-2019)
