Tachometer Mayhem
Old Oct 17, 2017 | 05:19 PM
garywalsh's Avatar
garywalsh
Default Tachometer Mayhem
Okay guys, why does my tachometer light up like the sun is behind it sometimes when I step on the peddle firmly? Can’t find the answer in the owners manual or on line. I own a 2015 Stingray without Z51. What the heck is happening?
Old Oct 17, 2017 | 05:26 PM
LbulletM's Avatar
LbulletM
If it's a manual, it's a shift indicator. Yellow and then red.
Old Oct 17, 2017 | 05:36 PM
speedlink's Avatar
speedlink
As was said the owners manual is your friend.
Old Oct 17, 2017 | 05:42 PM
Curahee's Avatar
Curahee
Been a long time since I've seen the "...is your friend" schtick.
Old Oct 17, 2017 | 09:52 PM
garywalsh's Avatar
garywalsh
It’s an automatic and it’s not the painted on shift indicators. It lights up from the back like the sun is coming up. Only lasts a second or two.
garywalsh's Avatar
garywalsh
Couldn’t find any description in the owners manual.
Old Oct 17, 2017 | 10:00 PM
Zymurgy's Avatar
Zymurgy
Moderator
It's telling you that you are approaching red-line. A yellow glow around the tach which will go red if you get really close to red-line. It goes away when the revs drop down due to upshift or letting off the accelerator.
Furthermore, the red-line point reacts to engine temperature. When "cold", red-line will be much lower and will gradually increase as the engine reaches normal operating termperatures. It also has a lower red-line during the first 500 miles (until break-in is over).
Old Oct 17, 2017 | 10:03 PM
LbulletM's Avatar
LbulletM
What the hell is a painted on shift indicator?
And from the most recent response, looks like I was still right. Are you in manual mode when it happens?
Old Oct 17, 2017 | 10:27 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
It doesn't matter if you're in manual mode or auto. Zymurgy is correct, it lights up as a "halo" around the center gauge telling you you're getting close to redline, which increases as the engine warms up.
For the OP who asked the question, it's normal and nothing to be concerned about.
Old Oct 18, 2017 | 12:16 AM
LbulletM's Avatar
LbulletM
Haven't been in an auto, so wouldn't know. Could definitely see the OP's confusion. Seems like a superfluous feature when it's going to shift itself anyways.
Old Oct 18, 2017 | 12:25 AM
Zymurgy's Avatar
Zymurgy
Moderator
One could be driving the auto in "manual mode", meaning you need to tell it when to shift. Therefore, it is not superfluous.
Old Oct 18, 2017 | 12:52 AM
LbulletM's Avatar
LbulletM
If you read the whole thread, I mentioned manual transmissions and then manual mode. Those both make sense.
The superfluous comment was toward an auto in auto mode.
Old Oct 18, 2017 | 05:54 PM
garywalsh's Avatar
garywalsh
It seems to light up around 3500 rpm? That’s not close to redline?
Old Oct 18, 2017 | 05:57 PM
garywalsh's Avatar
garywalsh
The individual permanent line markings around the outer edges of the tachometer.
Old Oct 18, 2017 | 06:00 PM
LbulletM's Avatar
LbulletM
Is that when you just started the car? The "redline" moves as the engine warms up (indicated by extra numbers and colors around the tach) until it gets to actual redline, and then the extra markings go away.
Old Oct 18, 2017 | 06:26 PM
Steve_R's Avatar
Steve_R
With the engine cold it will light up yellow at 3500. As the engine warms up that number increases until the actual redline (6500 I believe?) when the engine is fully warmed up.
Old Oct 18, 2017 | 06:31 PM
Zymurgy's Avatar
Zymurgy
Moderator
Yep, precisely what I stated back in post #7:
To Tachometer Mayhem
Old Oct 22, 2017 | 12:37 PM
garywalsh's Avatar
garywalsh
Is this info in the owners manual? I certainly can’t find it! Thanks for your help.
Old Oct 22, 2017 | 07:46 PM
garywalsh's Avatar
garywalsh
After further testing it appears this feature disappears after she is fully warmed up? Can you confirm this?
Old Oct 22, 2017 | 08:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
No, it is always there, just need to push the revs higher.
