My 16 base stingray was way quieter than my current 17 GS, those big Run flat tires are loud and there are currently NO replacements for them in RF as I can find and not even any all season tires for the rear. I think there are some for front sizes. I got some of the thin insulation from LOWES and slid under seats, behind seat, over carpet in cargo area and placed 2 harbor freight black moving blankets over them and then put a custom Lloyds mat over this in cargo area and it cut noise down a lot. Cheap and you can't tell they are there and the lloyd mat covers it all up in the cargo area. I didn't want to rip any carpet up to install anything so I put it over the existing carpet. Good luck
I did the same thing with the Blockit kit, HF moving blanket, and Lloyds mat. I used the Blockit squares behind the seats though. Made a difference.
I tried the Blockit kit on my 2016 Z06 coupe. The "before" tire roar was indistinguishable from "after" tire roar. My wife has super hearing so I subjected her to a blindfold test. With a blanket covering the rear interior, I did four 'with/without' trials. Like me, she detected no difference in tire noise.
OTOH, I test drove back to back a 2017 Stingray vs Grand Sport vs Z06 under controled conditions (same road, same speed). The Stingray was noticeably quieter than the GS and Z06. This tells me the only thing that matters is the tire size.
I'm wondering how weird it would look to make one like that, but with a window in it. Maybe double-pane polycarbonate.
I had a half partition in my C5 Z07, and it worked great except that it would get loose under hard braking (think track). I seem to recall that it did knock down some of the sound.
Heck, our C7 Coupe is totally stock and I can't see behind me (compared to our C6)
I have purchased a few things like insulation material etc and am planning on pulling out the seats and carpet and lining it Weill with sound proofing material... my next plan is .... there is a material that hooks to the tethers and drops down to the hump right behind the seats...I'm considering removing that material and making a baffle that will sit there. It will be below the rear view mirror so you'll be able to see out of it and it will all be out of the way of the rear speakers..... It has to work....
say Wile E coyote....
My 15' Z51 was quieter than my C5 but louder than my other 3 cars. So, I installed FatMat and the companion rubber product, all over the rear, and the bulkhead behind the seats. I also replaced the tires with non-run-flat Pilot SS. The car is much quieter, except on grooved concrete, which also upsets my two other cars with Pilot SS. My next noise improvement planned is to pull the rear fender liners and cover them with Fat Mat. Since most of the noise is generated from the tires, it seems logical to place as many sound deadening layers between them and the cabin.
Changing tires from Michelin Pilot SS probably would help, say to a different tread design like I have on my Explorer Sport (Continental DWS 06 all season), but unfortunately most max performance summer tires all have similar tread designs, and I don't believe Conti DWS come in correct size for a Z06. The Conti DWS are far quieter than the original Exp Sport tires so tires do make a big difference.
If you need tire noise info, I would contact a Tire Rack specialist.
I installed the blockit deck mat and seat back pads in my '16 Z-06. I did notice a subtle difference, but our roads are nearly all asphalt. I'm still on the run-flats, but looking at other options in the spring.
I swapped out the run-flats on my E350 for Conti's and the difference was amazing. Much quieter and much better ride through the mountains here.
I hope you find a solution. Sure is a fun car, but noise is part of the package...
Just did 1100 miles NJ - NC and back. One other option is wait until you get old - you won't hear as much. There was only one stretch of road that was really bad.
IMHO easiest and biggest reduction is switching to non runflat tires.
In my research, the only noise measurement done showed no difference between run flats and non-RFs. I suspect that the "big difference" people are just repeating what others have said, not first hand earwitness comparisons.
It seems that tread pattern and depth are the issue with noise, sidewall stiffness doesn't seem to have much effect.
Switching from a well worn set of tires to the exact same model, but new, will usually reduce noise noticably. I noticed that on our C6s.
Probably true.
So what does work? You're pretty quick to point out what doesn't so what's the solution? Just tire width?
My guess is that two things affect noise, tread width and tread depth. The observation that OEM Michelin run flats have both wide tread (335mm for the rears) and shallow tread (7.8 32 seconds) supports this. Toyo Tires have a 500 mile trial period that allows the buyer to get a full refund if dissatified with the purchased tires for any reason. My next move would be to get wide tires with deep tread. If that doesn't work, I'll go to narrow tires and deep tread. If still no work, I get my money back and go back to OEM run flats.
"Blockout" is typo, product I used is "Blockit". Either way, 'before and after' noise levels were indistinguishable from each other. Total waste of time and money.
