Road noise
Old Dec 9, 2017 | 03:42 PM
  #61
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Here is what I did. Can't say it made a big difference but I tried.
1. Switched to Continental DWS06 All Season non runflat tires
2. Installed a Lloyd's Luxe cargo mat
3. Put rubber foam mats behind seats under the carpet
Old Mar 13, 2018 | 08:24 AM
  #62
roadhog08's Avatar
roadhog08
Originally Posted by Spinny
Try replacing the tires with non-runflats. This made a big difference for me.
Old Mar 13, 2018 | 08:49 AM
  #63
Foosh's Avatar
Foosh
Originally Posted by roller11
In my research, the only noise measurement done showed no difference between run flats and non-RFs. I suspect that the "big difference" people are just repeating what others have said, not first hand earwitness comparisons.
Agree. The available noise data show no differences between PSS ZPs and and regular versions. Yet folks keep repeating the same antiquated and inaccurate info as fact. The placebo effect takes care the rest.
Old Mar 13, 2018 | 09:00 AM
  #64
montoya's Avatar
montoya
New tires are always quieter than old tires with worn treads- this probably explains most of it.
Old Mar 13, 2018 | 09:07 AM
  #65
bjones7131's Avatar
bjones7131
Didn't know cont. Dws06 was all season, good to know. I knew they had the non RF.
Old Mar 13, 2018 | 09:27 AM
  #66
fake's Avatar
fake
Tires thats the problem you need some good recaps!
Old Mar 13, 2018 | 10:03 PM
  #67
wgood's Avatar
wgood
I agree with Spinny especially when you drive in wet weather !!! I live in the pacific northwest and you can imagine driving with slick OEMS !!!! Wayne
Old Mar 13, 2018 | 11:05 PM
  #68
jimmbbo's Avatar
jimmbbo
The road surface has a yuuuge effect on cabin noise. My previous cruiser was an '11 Mustang GT Premium which had noticeable road noise, especially on rougher surface asphalt.
When I got the C7, I noticed it had more noise on familiar roads than did my Mustang, with a particularly aggravating amount being generated by the drum head aka the cargo bin floor. It seemed that every bump in the road was amplified through the cargo bin and bounced off the rear glass directly to my ears....
I considered swapping the tires to Michelin A/S 3+, but before plunking down $1400, decided to investigate Block It mats.
Before installing the mats I ran a ten mile course on known local roads and freeways to get a baseline noise level with my iPhone Decibel X Pro app. I installed the mats (a five minute job) and reran the same course. The result was a reduction of 2 - 3 db overall, and a significant drop in the annoying rear deck noise.
While the noise level is still noticeable and affected by the road surface, it is equivalent to the cabin noise in my Mustang, and more importantly, the noise spikes from the back have been significantly reduced.
Old Mar 14, 2018 | 01:05 AM
  #69
bankers1's Avatar
bankers1
I'm with jimmbbo. My ears are my db meters. I've done the Blockit mat, with the 2 extra matts behind the seats, some Blockit adhesive stuff for rear floor, up and over the "hump" and all around the drive train (behind the arm rest), topped it off with a layer of Loyds Total $ 345. and I'm ALMOST done, much better, but in 2-3 weeks, some Contis non RF are coming my way. Any resale market on 4 Mich OEM Cup's with 3,000 miles?????
Some one in this mentioned lexan/plex wall behind the seats, esp. for when to top is off....any "noise" comments pre and post install ? Anyone bought one ?
Old Mar 14, 2018 | 02:34 AM
  #70
fsvoboda's Avatar
fsvoboda
By the way, if you're planning to be touring in your C7, you might try loading with soft-sided luggage before doing anything else, and then rerunning your Db test. I suspect you'll find road noise from the cargo hold much reduced.
Old Mar 14, 2018 | 06:35 AM
  #71
BlueDevilZ51's Avatar
BlueDevilZ51
Anyone complaining about road noise must work in a office for a living. Driving my C7 is the only quite time i get even at 6500 RPMs is a lot quieter then my day at work.
Old Mar 14, 2018 | 07:23 AM
  #72
woodsguy's Avatar
woodsguy
"Blockout" is typo, product I used is "Blockit". Either way, 'before and after' noise levels were indistinguishable from each other. Total waste of time and money.
Agree, very little relief.
Old Mar 14, 2018 | 07:26 AM
  #73
woodsguy's Avatar
woodsguy
Thanks to all who have responded. "30MPH on smooth concrete roadway" was misinterpreted. I meant that concrete is way less noise than asphalt, and slow speed is less noisy than high speed. So under ideal conditions, the noise is acceptable with concrete/30MPH. But 98% of my driving is on non ideal normal asphalt road bed at typical around town speeds (30-50). On typical Chip and Seal road surface, Anything over 20 MPH is too loud. After 10 minutes driving the corridor between Longmont CO and Boulder CO, my ears were ringing.
Seems there are two types of solutions- thin butyl rubber (50-80 mm) like Dynamat, and thick foam like Blockit. Blockit was totally ineffective, perhaps I'll try the butyl.
Also, I wonder how much difference there would be between, say, a stock non-Z51Stingray and a Z06 in terms of noise. I would be willing to step down to a base Stingray, even with the stock skinny tires, if this would satisfy my noise requirement. As it is, all the wonderful performance/looks of a Z06 is wasted on me cause the noise is so irritating.
Anyone tried a stock stingray vs a Z06?
It is weird some surfaces no noise at all then get on the right asphalt and the roar is miserable. I understand these are "sport" cars, some sounds and senses are great this tire noise is not.
Old Mar 14, 2018 | 08:55 AM
  #74
roy817's Avatar
roy817
When I got my 16 2LT Stingray, I thought the noise was unbearable and was really regretting my purchase. I used Dynamat on the back and behind the seats, added the 3 piece BlockIt and put down the Lloyds mats. Really made a big difference. No problems with conversation or hearing the radio. Local roads and I95. Now just loving the car whenever I'm behind the wheel.
Old Mar 14, 2018 | 08:20 PM
  #75
Walter Raulerson's Avatar
Walter Raulerson
"quite" time
Old Mar 15, 2018 | 12:24 AM
  #76
Tron1's Avatar
Tron1
IMHO easiest and biggest reduction is switching to non runflat tires.
I sincerely hope you are correct. It does seem the runflats is where the intrusive road noise is coming from.
Old Mar 15, 2018 | 12:35 AM
  #77
Foosh's Avatar
Foosh
No, tire noise is NOT a function of the runflat design, PSS ZPs and non-ZPs test out about equal in terms of tire noise. The noise is primarily due to the the lack of insulation in the very thin rear cargo area floor.
You may find a slightly quieter tire that is not available as a runflat, but there's nothing inherent in the runflat design, which is only about sidewall construction, that makes them louder. If you think you can cure the noise issue by simply purchasing a set of non-ZP tires, you'll be disappointed unless you are particularly susceptible to the placebo effect, in which case you probably can fool yourself into thinking it's quieter.
To Road noise
Old Mar 15, 2018 | 03:07 AM
  #78
joemessman's Avatar
joemessman
Here was my response to road noise on another thread:
"The fun of having a Corvette is not only feeling the road, but hearing the road! What's wrong with you guys? Unbelievable.
Let me see? I'm going to buy a car and noise is one of my prime concerns. I think I'll start by shopping for a Corvette. Give me a break. "
Old Mar 15, 2018 | 04:34 AM
  #79
Skid Row Joe's Avatar
Skid Row Joe
Joe,
the last Corvette I test drove was a new C5 coupe back in the '90s. I test drove it one exit down the expressway in front of the Chevy dealer and back. The sound of the exhaust, with the road noise from the cavern was very noticeable and bothersome. I lucked out on considering a new C7 vert instead of the cavern hatchback. So glad I did. Almost no noise from back there. You need to get back on a vert.
Old Mar 15, 2018 | 08:41 AM
  #80
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Thought this Thread was one of the best on decreasing noise! The OP did his homework, spent a lot of time adding multiple layers of quality sound insulation and has dB data before/after and then after changing tires!
https://www.corvetteforum.com/forums...-readings.html
