Changed my tranny fluid-Wow!
Old 11-18-2017, 09:05 PM
  #41
traderfjp
traderfjp's Avatar
Originally Posted by Rebel Yell
Great tip trader, and what a deal. I wouldn't even crawl under the thing for 50 bucks.
I thought it was a fair price. It really only takes 30 minutes to drain and re-fill. I don't like anyone working on my car but I also don't have a lift and don't feel safe getting under my car with jack stands.
Old 11-18-2017, 09:58 PM
  #42
owc6
owc6's Avatar
Received 4,192 Likes on 2,681 Posts
Originally Posted by Red-C6 of Jax
The A8's are problematic enough without giving GM an excuse to void your tranny warranty. I have a GM extended warranty and if my A8 takes a crap, the bill is going to be on GM and not me. We have a member in our corvette club whose C-6 engine blew up and GM engineers spent two days going over his car trying to put the bill on him. They they were unable to do this and GM eventually paid 24K for a new engine.
I'm assuming this was a Z06?? Confused here.
Old 11-18-2017, 10:15 PM
  #43
DrDyno
DrDyno's Avatar
Originally Posted by Kracka
Not correct, read further down the link. They recommend D4 for your power steering, but D6 for your A6 transmission.
Thanks, Kracka!
The site has the headings listed in bold in the "box" above the application, within the box of the product above it. Since the heading "Automatic Transmission Fluid" was in the same box as D4 ATF, I didn't read any further. Thanks, again!
Old 11-20-2017, 12:48 PM
  #44
djnice
djnice's Avatar
Originally Posted by SFCTeach
That is just great I purchased from this thread top of page 2. What is the correct fluid from Redline for the M7 transmission?
http://https://www.corvetteforum.com...-fluids-2.html
Redline D4 ATF
Old 11-20-2017, 01:26 PM
  #45
traderfjp
traderfjp's Avatar
No. That is my next car. I own a 2014 7m, 3lt
Old 11-21-2017, 04:16 PM
  #46
SD_Dave
Dr. Dave
Support Corvetteforum!
SD_Dave's Avatar
Ditto on the OP.
Yesterday, I had my tranny and diff fluids changed on my '16 M7 SR with 27K miles of mostly city driving.
The tranny fluid was not real bad looking. The diff oil was black and had metallic particles. The magnetic plug (forgot which one) had a lot of metal dust attached.
Added Redline D4 to tranny. Added ACDelco 10-4034 Dexron LS 75W-90 Gear Oil to diff.
Gone are the grindy, rubbing noises I used to hear from the drive train. The tranny shifts are now super smooth. Actually even better than when new!
I read that the Redline D4 may not last as long as OEM fluid but that's fine by me. I'll change it again as needed even if that's only 20K miles or so.
I highly recommend this service for C7 with any kind of miles on it.
Maxie2U (11-22-2017)
Old 11-21-2017, 04:38 PM
  #47
MichaelO
MichaelO's Avatar
All very interesting, my A8 is great so far but who knows what the future will bring. Will keep this info for future reference.
Old 11-21-2017, 10:17 PM
  #48
djnice
djnice's Avatar
I take the it the OP was posting about smoothness of shifting the manual M7 trans after using Redline D4 oil, which is not applicable or suitable to the auto A8. If I am correct, his post had nothing to do with smoothness of shifting the A8. GM is very particular about the fluid being compatible with the TC Clutch material. I would not put anything in the A8 except what is listed in GM's latest TSB.
Old 11-27-2017, 02:11 PM
  #49
SFCTeach
SFCTeach's Avatar
Guys I was really concerned about having the wrong fluid ( MTL vs D4 redline in an M7). The vendor replied back to me and I wanted to post this so in the thread. My car is in hibernation mode so it wasn't freaking me out day by day that I was going to tank my tranny driving with the wrong fluid.
MTL Fluid
Popular replacement for and improvement over GM Synchromesh® (#12345349), Auto-Trak II® (#12378508) and Chrysler spec MS-9224
Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
Offers quicker shifts, Â perfect synchronizer coefficient of friction
Eliminates notchy shifting, even when cold
High performance gear protection and longer synchro life
Satisfies the gear oil viscosity requirements of 75W, 80W and motor oil viscosities of SAE 30, 10W30 and 5W30
Recommended for GL-1, GL-3 and GL-4 applications as well as where most special synchromesh fluids are specified
We have had a number of C7 Corvette including our own car a 2014 C7 that sees many track days a year running MTL in the transmission with no adverse effects and clean crisp shifts all the time. Also all of our C5/C6 cars also run MTL including our C6ZO6 NASA Eastern National TT1 Championship winning car.
SD_Dave (11-27-2017)
Old 11-27-2017, 06:21 PM
  #50
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by robert miller
I went to amsoil made a good diff in my car.
Yup - This...
https://www.corvettepartsandaccessor...smission-fluid
Did my personal GS about 2 weeks ago and the difference is
remarkable...
Regards
Chip
__________________
..................Click for
Old 11-27-2017, 06:53 PM
  #51
djnice
djnice's Avatar
MTL Fluid
I have also seen recommendations to do a blend of Redline MTL and ATF. If I recall correctly, the MTL is supposed to take load and heat better.
Old 11-27-2017, 07:06 PM
  #52
themonk
themonk's Avatar
Location: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
Received 1,456 Likes on 799 Posts
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
People say use factory fluid so my question is, what is "factory fluid"? GM doesn't make these trannys so why would they say that their fluid is recommended? I'm sure that this 7 speed is used in other manufacturer's vehicles so do they use "GM" brand transmission fluid or their own factory fluid which somehow is different than GM's even though the transmissions are the same?
Old 11-28-2017, 12:11 PM
  #53
djnice
djnice's Avatar
The M7 or Tremec TR-6070 is only used in Corvette. Tremec calls for Dexron III ATF, but they also say they have their own fluid that they recommend.
http://www.tremec.com/anexos/TREMEC_...0_Prod.Lit.pdf
https://en.wikipedia.org/wiki/Tremec...0_transmission
RPM, a company who modifies the TR-6070 to take more horsepower, recommends the use of Royal Purple SynchroMax. http://www.rpmtransmissions.com/page59.html
Old 11-30-2017, 07:35 AM
  #54
HoustonMidtown
HoustonMidtown's Avatar
I just got my car (early 2016) back from the dealer - I had (for the 2nd time) the TC/shudder problem (TC has been replaced once already). This time, they only changed the transmission fluid because that is what GM told them to do - it is unbelievable to me how much this improved the entire driving experience.
I didn't realize how "bad" my transmission was - I have only driven the car for 2 days, but have not experienced the rough shifts in the morning, the V4-V8 transition "nudge" has totally disappeared - I wouldn't know the transition happened if I didn't see it switch on the DIC.
I would highly suggest having your dealer do this if you are having any transmission issues.
Old 12-02-2018, 04:36 PM
  #55
Matthewstorm
Matthewstorm's Avatar
I realize this is an old thread.
What about Royal Purple tranny fluid? https://smile.amazon.com/Royal-Purpl...smission+fluid
How many quarts does the tranny take? What do people recommend for Diff fluid?
Thanks.
Old 12-03-2018, 10:53 PM
  #56
djnice
djnice's Avatar
I use either gm fluid or redline in the diff.
Old 12-04-2018, 01:58 AM
  #57
Jaykoh-Z51
Jaykoh-Z51's Avatar
Originally Posted by sunsalem
It's a simple situation...if it is under warranty, use GM's recommendations.
Otherwise you might have to foot the bill if anything goes wrong.
I'll be here all week...
This was my thinking as well. Had the dealer change my M7 fluid with OEM stuff...about 39,000 on the clock then. I have the extended warranty from Dennis. I didn't wanna chance anything there. So....originall fluid done AT the dealer so there is record of if...juuuuuuust in case.
To Changed my tranny fluid-Wow!
Old 12-04-2018, 04:32 AM
  #58
HorsePower Junkie
HorsePower Junkie's Avatar
St. Jude Donor '20-'21-'22-'23
How many quarts for the M7, and how many for the diff?
Old 01-29-2019, 06:54 AM
  #59
tadehz51
tadehz51's Avatar
m7 is 3.5 liters and the electronic diff for z51’s is like 2.9 liters
Old 01-29-2019, 10:43 AM
  #60
JMII
JMII's Avatar
Received 2,025 Likes on 1,349 Posts
Here is a DYI on the M7 tranny and rear diff fluid change that I found very helpful:
https://www.corvetteforum.com/forums...d-service.html
I used Mobil 1 Synthetic ATF Multi Vehicle Formula for the M7 transmission = 4 quarts
and Mobil 1 Synthetic Gear Lube LS for the Z51 rear diff (eLSD) = 3 quarts
The specs are Dexron III ATF in the tranny and AC Delco DEXRON LS 75w-90 gear oil for the diff so any fluids that meet those specifications should be fine. And yes you read that correctly - the manual transmission takes automatic transmission fluid. I've used Redline and Royal Purple in the past on my other vehicles, but Mobil 1 was available locally when I did my 'Vette.
Quick Reply: Changed my tranny fluid-Wow!
