Maybe there is a leak at the bead that seals off when the pressure gets lower. Might help to clean the bead and let the tire reseat. Are all the weights stick on? I have had small leaks at the bead caused by clip on weights.
You might try bleeding more air out of the tire and see if the readout drops below the 21 lbs.
Good idea, though I believe the sensors go into a sleep mode when not rotating, so it might take up to an hour (?) for the reduced pressure to show.
The experts will explain this to us...
If you are letting air out fairly quickly, the sensors may react without having to wait...
I forget because I bought a tool to read and trigger the sensors so I can read what the output is anytime.
Check the lock nut on the valve stem. There have been a few reports of leaks at the valve stem / sensor. Finger tight should be enough.
Good Luck
A slow leak that has no other symptoms (nail, found, other mark on the tire?). This would be the first thing I would check given that. I just recently had this happen. I noticed it awhile ago ( long after the last tire change), and it was losing about a pound a week. I bought a valve stem tool and tightened it up. It turned about a halve turn.
Solved the leak.
I have no idea why it started leaking tens of thousands of miles after the tire change.
I once had a new tire that had a slow leak. Several shops couldn't find the problem which turned out to a little rubber piece in the bead. It wouldn't leak when off the car but would when driven.
Give Nitrogen a try. I adjust pressure about every six months using Nitrogen in stead of adjustments every three to four weeks with air compressor.
I use air and still only have to adjust the pressures when the seasons change and I need adjust for a shift in ambient temperature...I do try to adjust the pressures when the humidity is low..
Makes me wonder why you had to adjust more often... I doubt the apparent lower fluctuations is due to the nitrogen, but rather just that bottled nitrogen has less moisture to expand... The nitrogen itself behaves by the the same gas laws as oxygen, argon, and all the other gases.
If the oxygen molecule leaks out faster than the nitrogen molecules, then over time, all the oxygen would leak out, so that even if you replaced the 20% oxygen with air (78% nitrogen), the tire would eventually contain only nitrogen..
Consumer Reports did a study in 2006 where they measured pressure loss of nitrogen-filled Vs air-filled tires over a one year period. They took 31 pairs of all season, automotive tires (H and V speed rated). One tire of each pair was filled to 30 psi with air, the other tire from the pair was filled to 30 psi with nitrogen. All 31 pairs were then set aside, outdoors for 12 months.
Their conclusion was that nitrogen does reduce tire pressure loss over time, but the reduction is only 1.3 psi.
I get a warning that the left front tire pressure is down to 21 pounds. I get the tire filled, and a few weeks later, I get the same message again.
It is ALWAYS the left front tire, and the pressure is ALWAYS 21 pounds.
This is an ongoing problem - has happened at least a dozen times.
So why ALWAYS 21 pounds? Why not 20? or 18? or 23? Why 21?
Both the dealership and Goodyear say there is no discernable leak in the tire.
Hmm, sounds like the first time it happened you should have been more worried about why it was getting lower rather than why it was 21 and not 22 or 23 pounds! If it happened a dozen times you should find out the cause!
Could be a slow leaking valve or a bean not sealing on the rim! Have the tire removed and remounted. Or put soap solution on the tire valve and bead yourself and see if there are any fine bubbles. !
My new Grand Sports left rear would lose 3-4 psi/week, I told the dealer about it at the 500 mile oil change servuce and they discovered the the TP sensor was leaking. They replaced it and it has been fine.
I am sure the Consumer Reports Study was controlled and I'm sure the results were beneficial for their need. I live in Mobile, Alabama, the relative humidity is quite elevated along the Gulf Coast. I am believe the high RH air that is being pumped into tires (no dryers on compressors) here has something to do with the need to add air monthly, Quarters, Quarters, Quarters. Over ten years ago I solved that problem by using Nitrogen in my tires. I get more miles out of my tires, maintain a more stable pressure in my tires and only make pressure adjustments every six months or so. I hear many negative arguments against Nitrogen on the forum but it works for me!
